Regarding the comments about an unconventional “Japanese” thermal interface being used, I’d be curious what it is, or any info on it, purely for curiosity’s sake only. I’m quite familiar with all the various ‘modern’ TIMs being used for mass production & hobbyist use, as I’ve spent countless hours spec’ing this stuff out, modeling thermal performance for various bond-line thickness & RMS surface roughness, as well as testing / verifying / validating the design & thermal simulation model in controlled environmental chambers for various consumer & commercial products, etc, etc…
On my sample, there was “something” that was clearly rubbed / cleaned off the head where the leftover residue looked exactly like it does after wiping off a conventional, (metal)oxide impregnated thermal paste from a CPU heat spreader… I’ve used & spec’d more than a few designs implementing some of the fancy ‘phase change’ TIMs for unique commercial applications requiring it for initial production cost & field maintenance reasons; this was & is not the case here.
Regarding some of the other comments, I think the 25 posts in this thread, in only 24 hours, shows just how satisfied the overwhelming majority of folks are with their purchase of the M43 & how well-rounded the actual engineering / design is for a flashlight of this type (which is why I purchased it & chose to fix the manufacturing defects rather than send it back). My intent in posting my findings wasn’t to cause a mass panic, nor cause folks to be dissatisfied with their purchase, just give a heads up for a potentially serious manufacturing flaw that can be fairly easily fixed, & vent a little bit about the other manufacturing issues I found in my sample.
From a few of the comments, it appears one or two folks may have taken my post in a strange way… I purposely differentiated between “Design / Engineering” vs “Manufacturing / Production”; they are not the same, although most consumers confuse the two, or simply choose not to understand the difference when critical analysis is given towards products / brands they are emotionally attached to. It’s good to be skeptical & challenge the legitimacy of what you’re told (especially on the internet), the world needs more of this; however, it is also wise to be cognizant of one’s own biases / distortions / conditioning, especially in areas of high passion
Again, “Design / Engineering” quality wise, I’m ‘8.5 out of 10’ satisfied with the M43, especially considering the relative “value” price point it now costs. “8.5 out of 10” on my personal scale is a rarity to find in a mass market product; I wouldn’t even rate many of my own consumer product designs this high due to the cost constraints, cultural incompetence (politics), & greediness I had to appease in former work… In a nutshell, no one should feel bad about their purchase of the M43; I really like mine, it’s one of my favorites now that I fixed the manufacturing defects to meet the designer’s engineering specification
However, it still stands that the “Production / Manufacturing” quality of my sample (i.e. the manufacturing process’s ability to adhere to design / engineering specification) was highly flawed to the point of being completely unacceptable. If it were one single defect alone, I could chalk it up to “Things Happen” & it wouldn’t be much of an issue to me; however, there were 5 separate, unrelated manufacturing quality defects in my sample, which is highly indicative of an overall manufacturing process that is out of control, complacent, & not maintained due to a lack of necessary negative feedback loops. My posting of these manufacturing defects will hopefully be the necessary negative feedback loop to correct these issues. Maybe mine was built at the last hour before Chinese New Year break this year; however, this is still not a justifiable excuse if quality is of any concern to the manufacturer…
Thanks for the warm welcome folks. I’ve lurked on here the past 5 or so years, & CPF for about 8 years. I’ve built lots of lights, modded plenty of mass produced ones too; finally had something that irked me enough to sign up, so here I am
