Lexel wrote: “I am working on a CFT-90 driver for GT”.
Hmmmmmm……I think I already know where part of my holiday allowance will go to
Djozz and I did some measurements this evening, at 21, 13 and 8 meters.
Djozz’ light performs quite a lot less less then mine, so we measured only my light at all three distances.
And Djozz has his work cut out to find out what’s wrong with his light. :rage:
Results:
Djozz light: 21 mtr = 832.167Cd
My light at 21 mtr = 1.142.190Cd
Mine at 13 mtr = 1.139.060Cd
Mine at 8 mtr = 1.142.336Cd
(We measured with Djozz’ calibrated Gossen Luxmeter and deducted the ambient light @ 61Cd).
At first I was baffled by the lower readings at higher distances and thought it might have to do with the convergance of the light but I saw others posting
similar results, so……it looks like the BLF GT is already fully focussed at 8 meters.
1.142.336Cd is not bad, not bad at all, but still a little bit lower then I had hoped for.
So, thinking of replacing the led with the latest bin and maybe giving it a little more power as well, say 2,8A instead of 2,5A.
Then again, a custom Lexel driver and a CFT-90 might be really nice as well
Cheers and wishing you all very bright days and nights,
Nico
Driving a XHP70 with just a 0.047 Ohm resistor will be disappointing at 6V
This would result in 5A
Also switching frequency would not be ideal, the diode would be quite close to its limit
I changed the Inductor, MOSFET, capacitors and diode with better parts for higher currents also the switching frequency will be set to a point where the drivers efficiency gets optimal
Also reducing the current sense resistor and lowering the current control voltage divider helps reducing heat
I should get next week the 20-40A synchronous Buck driver boards that I developed for CFT-90 and going to assemble and test the first prototype
