Bought a XINTD C8 from Int'l Outdoor Store and Hank was kind enough to provide me with the picture of the driver(I have yet to receive the light).
Thanks in advance
Thanks in advance
I saw this driver from LCK-LED
V10
Item Price: $6.00 $5.52
Constant Current LED Driver Board - 5 Mode, 3.3-4.5V 3.0A
Description:
- Accepts one Li-ion (e.g. 18650)
- Direct drive P7 LED
- 10% 45% 100%
- High frenqency PWM
- 17mm diameter PCB
- Gold plated PCB for superior conductivity
Dimension: Diameter 16-17mm*Height 4.5mm
Input Voltage: 3.2-4.5V
Output current: 100-3500mA
Modes: High/Mid/Low/Strobe/SOS
Testing CSX0I P7 LED
Vin(V) Iout(A)
4.1 3.3
4.0 3
3.9 2.9
3.8 2.7
3.7 2.3
3.6 2
3.5 1.7
3.4 1.4
3.3 1.2
Does anyone have this driver or could compare it with V10+?
Hi oldbobk
When did you order yours?
Considering how well engineered the XinTD looks, I would be suprised if they didn't test out the drivers before they used them. Seriously, the light looks like it was built by a Flashaholic, or at least someone who understands the concept.
I have one on order, if the driver fails, I will put in a 105C.
Is it the same with LCK-LED driver or the XINTD C8 have an updated and improved driver being a +?
I still have high hopes on the driver of this new lights.
Hello!
I presume the driver being discussed here is this one:
Link: http://www.kaidomain.com/p/S005025.SSC-P7-Li-ion-5-Mode-Driver
Looks neat, although with blinkies.
I wonder how good would this be for S2/S2+ hosts, I see in-series current limiting resistors which could be swapped to fine tune output current. Any idea about the PWM frequency?
Cheers fellows ^:)
