Very nice spec and beautiful. But can you publish your test report for the spec? I think every brand should do that as standard product data. If Haikelite do that, Haikelite will definitely be standing out of the crowd of many brands.
I want to see more of this light. Why no videos and beamshots all over the internet? The form-factor is so much better than the heavier (Astrolux/Mateminco) versions.
I had this light and a few words from me.
Good, solid and quite heavy. It’s better in your hand than BLF Q8 because it’s better balanced.
The button is a bit rubbery but works well. Of course, there are some drawbacks. Poor centering of the diode, I had to improve. Thermal paste of poor quality, because under the influence of temperature, the reflector begins to evaporate and dull. I had to clean everything and apply my own paste. The diode was supposed to be NW and it was almost there, only in low power. In the turbo the color shift is large and with 5700K it lands at 6400K. Fortunately, it is under the BBL line so the color is pure white. The turbo shines a long time because the thermal protection is not aggressive, but the flashlight can get hot.
Batteries connected in series, power consumption from one piece is 2.5A. In total, it gives 40W. I reached 2,200 lumens and 252,000 lux on fresh batteries.
One more disadvantage, but it’s probably my copy, it’s a battery drainage of 6mA. Generally, for a price with a coupon, quite an interesting proposition, but not without flaws.
With OFF:
Click - on.
Double click - Turbo
Holding … - unless moon
With ON:
Click - off
Holding down is a change of modes low, medium, high (there are several levels)
With the turbo click back to the previous lighting mode.
In addition, the flashlight has the memory of the last mode, of course, except for turbo and moon.
I do not have this flashlight anymore, but as I had compared it to Thrunite V6 and MT07S HI it shines on. It has a more tight beam and a little more lumens. It was already visible.
Here are my measurements (TURBO):
Color (NW) 6399K (5710K in HIGH) under BBL (x:0,316 y:0,318)
2.5A from the cell, batteries connected in series, which gives us about 40W
2202 Lumens
252000 luxs
Range 1005m
After 6 minutes the temperature reaches 53 degrees Celsius and there is no descent down from the turbo.
Weight 740 grams with batteries
Dimensions 181x66mm
