How can you tell strobe is hidden? I can’t find where they described the UI. Strobe is hidden would definitely make it worth considering. I hope it is easy to take out the PCB to swap the emitter.
Hiddden strobe. Blinking etc, is (iffy)ok.
Non existent is 100%.
Lo/Med/Hi or Lo/Hi is perfect I reckon.
They finally starting to do torches that aren’t cluttered with all these “you never use” controls on them.
This is probably what LT calls the Lumintop Tool AA 2.0, with 4 modes + strobe!
Maybe they have improved some of the things that were not so good on the V1.0…
Edit: hope this will be sold outside MD…
EDIT 2: Assuming the switch will be electronic like the Tool AAA version (Titanium?) does anyone know if that switch / mechanism would work properly with other kind of drivers, or only with the proprietary one?
Thanks in advance
If you are looking for a 14500 light with no strobe, Lo/Med/Hi, always starts in Low, very solid clip, AA compatibility, over 500 lumens, then Sofirn SF14 has it nailed. Now available in version 2 with very slight differences but still meeting that spec. This Vega looks very similar.
When you say very similar, what are you comparing with it?
SF14 has 3 modes; LT Tool AA 2.0 / Vega AA has 4 modes + blinkies.
SF14 has max output (on Li-Ion) is 550 lumens; LT Tool AA 2.0 / Vega AA max output (on Li-Ion) is 650 lumens.
No problem mate
On the left there is the SF14 (1.0) and on the right there is the LT Tool AA (1.0), that is probably just some mm longer than the Vega version due to the tail. They differ a bit, in length and diameter!
On the middle, the Jaxman E3.
Hey.
Those series of tube lights are mainly oh so boring looking.
Just more baby S2’s.
I like the ones with more style/shape. smoother, with curves
Something like a Astrolux AO1 up in size to a 14500.
and C8 with curves smoothing up the bottom half.
Get away from the tubes. sq edges and lotsa fins.
My lo/med/hi twisty. NOTHING else. with max of around 460.
is my little Jetbeam JET1 MK Pro.
The “nicest” looking comfortable “feeling”, in the hand, to carry.
Is my old Skyray S-R5 18650. With the C8’s not too far behind them.
"The stainless steel button switch allows you to cycle from low mode all the way to turbo mode with just a few clicks—and if you click it six times in succession you can access strobe mode for emergencies and signaling."
It's 30$ would you rather have a 35$ D4 or a 30$ FW3A instead ?
To me this is a no brainer .I even questioned the thought of even making a AA tool .Not one of lumintops finest ideas .Right up there with the med/high /low driver everyone hates .
I’m a big fan of WW and NW but I can’t tolerate yellowish tint. It’s these emitters that are too far above the BBL that makes the NW look piss yellow or greenish and give NW a bad rep. My Nichia 219B 4000k and Cree 5D tint are below the BBL and don’t have any yellowish appearance at all.
Here’s the new message from Massdrop regarding this light:
_Hi everyone,
We have an update to share with you about the Massdrop Vega AA/14500 Aluminum Flashlight.
We just finished final quality control checks. While we are happy with the overall build quality, fit and finish, we determined the Massdrop Vega AA/14500 Aluminum Flashlight was produced with some differences from what was originally communicated in the drop.
The original product featured a magnetic tailcap with the titanium clicky switch. The flashlight will now feature a titanium clicky switch and a separate magnetic tailcap that is twist-activated. We apologize for these changes. We’ve posted a few images of the change below for your reference.
For any inconvenience caused, we will add a $5 credit to your account, which will be automatically applied to your next Massdrop purchase. This will remain active for a year, and will automatically apply as a discount at your next checkout.
If you prefer to cancel your order, you can do so on your transaction page: Home | Drop
If you have any questions, please feel free to reach out.
We look forward to you receiving and enjoying your Massdrop Vega AA/14500 Aluminum Flashlight soon._
