Vapcell INR14500 L10 1050mAh (Purple) 2020
Official specifications:
Model: INR14500 L10
Type: Flat top
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 1050mAh (0.2C discharge)
Min capacity: 1000mAh (0.2C discharge)
Weight: Max: 22g
Internal resistance: Max:66mOhm (AC 1kHz)
Standard Charge: 500mA,CCCV 50mA cut-off
Quick Charge Current: 1000mA
Max Continuous Discharge Current: 3A
Operating Temperature: Charging, 0°C ~ 45°C, Discharging, –20°C~75°C
Storage Temperature: –5°C~35°C
Storage Humidity: <75%RH
This is a high capacity 14500 LiIon cell frm Vapcell.
The two cells match nicely and the cell has lots of capacity for a 14500 cell, but the cell is not for high current.
Conclusion
This is the highest capacity 14500 cell I have tested to data (Spring 2020), but it is for moderate current draw (Preferable not more than 1-2A), not for high current.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
