Keeppower 16340 850mAh P1634C2 (Black) 2020
Official specifications:
Voltage: 3.70V
Rated capacity: 850mAh
Minimum Capacity: 800mAh
Discharge cut-off voltage: 2.50V
Charge voltage: 4.20V +/- 0.05V
Standard charge current: 500mA
Maximum constant discharge current: 3A
Protected LiIon 16340 batteries from Keeppower.
The two cells do not match perfectly, but being a protected cell it do not prevent using them in series.
Conclusion
The battery has good capacity for its size and protected makes it safe to use in series configurations, but as usually for protected cells it is a bit longer than a standard cell.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
