I recently received this light from Manafont:
This aspheric-lens sporting thrower is a monster in stock form. It draws 1.46A at the tailcap on HI, which is quite a bit for the stock XR-E (EZ100 die.)
After my unfortunate discovery of the paper-thin heatsink on the UF-V4`recently, I wanted to peer inside this hard-driven light. SURPRISE ! There's a hollow pill !!!
Weighing in at a staggering 10 grams, the pill's lack of thermal mass will guarantee a dead XR-E soon enough.
Don't own a lathe? Here's a solution:
Next to the pill is a length of thick copper bare wire (~4.5mm), sourced at a local DIY retail store. (Menards)
I measured the interior dimensions of the pill, then cut the wire pieces slightly shorter to allow driver component clearance.
After a bit of sanding, the test fit revealed a nice symmetry.
I chose to use the setup as-is, without filling the gaps with smaller wire for simplicity's sake. You may choose to do so.
Below, you can see the original wire pass through holes:
After liberal application of Arctic Silver and overnight curing, this is the result:
I rolled silicone-infused parchment paper over tiny mandrels (toothpicks) to maintain the wire pass-through. After removal:
Next, comes the new emitter and driver. You may choose to re-use the originals, safe in the knowledge that you have a copper-cored pill that now weighs 39 grams !!
This method will work on most hollow pills, so have fun.
