Sofirn New Arrival LT1S
SELL OUT RISK: HIGH
20% OFF LT1S
CODE: H7XBL8UY
Sofirn LT1S is a powerful and lightweight camping lantern. The LT1S can also operate as a directional light. Runs on one 21700 battery; This lantern features a USB-C port for convenient charging; Giving out max output of 500lm with Red Light Mode.
Let me know if you are interested in LT1S!
Is there anything you want to know about the flashlight?
Maybe. We need more information.
  • Which LEDs? How many?
  • What is the UI?
  • What type of driver?
  • Any problems with heat (was a problem on the Zanflare T1 because the LEDs were around the battery)?
  • Dimensions
Purchased two … looks good.
Many thanks.
Does it come with an adapter to use an 18650?
Can it use regular flat top 21700 battery?
is the beam and led placement the same as the original LT1?
which leds?
Is the UI modified Anduril? Will you abide by the license terms and publish the source if so? Is there a UI diagram?
Where does the battery go?
Yeah I have so many questions haha, most of them already asked above :innocent:
The Aliexpress listing suggests a lot more LEDs and 3 channels!
Purchased this as soon as I saw it was released, and before I saw the discount. No regrets. Love the LT1 and love red LEDs, so this is perfect!
What's the parasitic (standby) drain?
same here xD
Does it maintain flat output regardless of brightness and battery voltage?
Where are the leds located, around the battery tube like zanflare T1 or on top like LT1?
Purchased one yesterday, might get another if there is a discount.
Thanks
10% off with the code in the first post.
Yep
NO, it is Sofirn designed UI
No, LTIS uses CSP1919 2700K*18, CSP1919 6500K *18, and Lattice Power Red LED*4
