I have had two units of the same 4000k heads running on a single cell for about 30 minutes, Rechargeable cells
Just checked cell voltages
One at 1.100 and one at 1.188
The single cell head unit will not power on with the lower voltage cell. Yet the x2 cell head unit power up
I’ve been running mine exclusively on 10440s. I bought 8 in all flavors.
1, Ignore / gift / discard 6500ks, they’re pointless. Output not visibly any higher yet tint and CRI much, much worse.
2, WK01 and WK02 4000k seem to use the same drivers. Their heads are interchangeable w/o any visible difference in performance.
3, WK01 w/10440 has higher output than WK02 w/ 2x AAA. Also, 10440 seem to largely remove SST20’s green tint.
4, 2x 10440 will instantly fry WK02. I’d only recommend WK02 if you can find and charge quality 10850, or really prefer the longer body that you’re willing to use 1x 10440 w/ a dummy cell.
5, It seems to be unregulated direct drive. Output will gradually drop to 50% @ 10 min.
6, W/ 10440, high is only visibly marginally brighter than medium, yet heats up much, much faster. I mostly stick to medium.
Point number 2
I am not sure they are the same… both the 4000k and the 6000k units, each single cell head unit had a higher cut off voltage… the single cell units would not light up when cell voltage was below 1.17, yet the 2 cell versions would still come on down to 1.08 volts
I am after the low brightness for cockpit use, and prefer the longer 2cell units as the ‘hang’ better in the flight suit pen pocket
