I have the original 980L, and I also bought what I thought was the FandyFire clone in bronze colour from ebay, when I got it, it was branded TrustFire, but has 3 rounded flats machined on the battery tube like my X9, and thats where the logo is. The clone is still a good light though, I think it is 90% as good as the 980L, both in brightness and quality, body and machining are good, parts from one fit the other, it is almost as bright but the tint is not as warm and the spot slightly larger, there is a bit of a ring corona around the centre spot, but you don’t notice it in use. Considering the price, I think it’s a bargain.
This one is listed as an A9, and apart from being black and having the same body (in the pictures at least) as the real 980L (no flats on battery tube), there are a couple of differences from the 980L, and they look to be the same differences my clone has. The clone’s reflector tightly encircles the LED, where the 980L’s has some space around it. Perhaps this explains the slight ringiness of the clones beam.
My clone has alloy bezels, and they are slightly thicker than the 980L’s stainless ones.
The bodies are almost identical, one of the machined grooves, where the battery tube screws into the head, appears slightly narrower. It could just be the battery tube screws in a little further, insignificant, but I think it makes the overall length a mm or two less. The threads are the same and the parts swap no problem.
The 980L has a naked spring inside the tail cap, the clone has a brass cap over it’s spring.
The clone feels a little lighter too (npi) but I haven’t weighed it.
The clone is also 5 mode and the 980L 3 with no discos. Both have mode memory. Sorry, my mistake, the clone has no memory, it always starts on high after a couple of minutes. The original has mode memory.
The clone actually has thicker GITD O-rings, so should be reasonably waterproof
The clone tail stands, the original, as it came, does not.
I ordered a couple of these black versions because I really like the size, style and brightness of this light. If they are as good as my bronze clone, at this price I will be very happy. If they are as good as the original 980L, I will be ecstatic! Good luck
