12v to 3v ?
Have you tested the socket in the truck to verify it is indeed outputting 12v?
I have a trunk light socket that outputs around 5v
Dang that says 9v… guess im about to do a bit of testing here.. nothing but rain and not burning my fingers or my work station. Lol
You could just test it?
Don’t you have a ~4V source to see if the led light up
a fully charged battery or maybe 5V from a USB cable
if the leds light up they are single chip. or “3v” class and you can just replace the resistors with lower values to get the brightness you want.
if not you need a boost converter
About to see if the whole row will light up with 4v
Not the whole row, but i got 2 at a time on 4v..
You got 45 leds and the circuit is designed to work on 12V nominal (fully charged car battery is +14V).
I’d say we’re looking at 5S9P setup. Every resistor limits the current through the 9P branch. Vf of a single led at about 2.5V would result in 12.5V, at 2.7V that would make 13.5V. rectifier is there as the polarity protection and will also drop some voltage. Most likely 0.7V times two. It’s a primitive way of safe operation in a car.
Giving this CC led driver another chance, first 2 would just come on by itself, even turn on/off if i slid my finger over it.. this 3rd one seems to work. Added in an on/off switch… if it stays working ill just find a different led to us as a lamp.. this is just to test..
Welp, didnt burn me fingeerrs ore me bench down.. so all is good. Got some 750 resistors out of it and learned a bit more about led’s..
I will check back in when i find a suitable light..
They are Likely 75Ohm
I would have tested the light with this resistors before removing them… so you could have get an idea what the voltage drop and and thereby drive current is.
Don’t know how this is working if they are all in parallel?
750 marked resistors are 75ohm.
You can see in that last led row pic.. they are linked by 2 somehow.. must be more going on under them i cant see. I took the resistors and tossed it, it was pulled before the truck was scraped to begin with. No loss.
Resistor markings take a bit of getting used to.
4R7 = 4.7ohm
470 = 47ohm
471 = 470ohm
472 = 4.7k
473= 47k
Then you have oddballs like..
01D = 100k
I cant just look at a ceramic resistor and tell you what it is, always got to look up what the color bands represent.. i got one big ol thing, if i remember right its a 5 ohm.. basically a dang heating element lol.. dont know why i keep crap like that..
