This sounds like what is happening to me.
Just to answer everyone. I did use solder paste and a little extra solder but not a lot.
I am going to go and re-flow it now and see what happens. Thanks for all of your help.
Marc.
Marc.
OK, a quick update. It turns out the Sinkpad has been made poorly. The screening/coating was slightly deformed and had raised up a little so more solder and and reflow worked.
One other problem I have noticed is the + is very close to the edge of the Sinkpad. This causes a problem when installing it into a P60. Because the Sinkpad is already larger than the star it replaced the positive wire kept shorting on the pill.
Overall i’m not that impressed with them and looking at the design I think the Noctigon’s that intl-outdoors have, look better. Less filing and arsing around I would imagine.
I am talking about the 16mm Sinkpads by the way. I have a 20mm which looks a lot better to use.
Marc.
If a 16mm shorts out against the pill you need to check your soldering skills. ;)
The solder tabs have been moved to the edge because the wires would get in the way of most reflectors..
My soldering skills are good. Used to be my job, but on my Sinkpad the solder tabs are almost on the edge of the star. Maybe a tenth of a millimetre. That’s very close even for the best of us.
Marc.
Probably best to use them in a pill that will take a 20mm sinkpad. That will give you som wiggle room.
Get some thin teflon sheet and slip it between Sinkpad & pill, if it's really that much of a problem. But, it really shouldn't be a problem. You think the pad location on the 16mm boards is compromised? Check out what you're left with when you cut a 20mm Sinkpad down to 16mm (16mm left, cut-down 20mm right):
And both those are with 22AWG silicone wire.
It's not uncommon at all to have to trim off stray solder with a sharp knife/x-acto/whatever, even when you've got the right amount of solder and it's well-fluxed and what would be, in any other application, a perfect solder joint.
Worked fine for me in a P60 pill:
My 16mm Sinkpad is as tight as yours in the pic. In fact it had to be filed down a little. I’m not saying they are rubbish, just saying the noctigon look better designed.
Marc.
My sinkpads arrived last week. Very nice. Are the noctigons better? From the pics and reviews it looks like it. The noctigons aren’t trying to also be 10mm boards, and I think as a result have bigger bond pads. The noctigons also have flat bases without the little indentation below the emitter. It remains to be seen whether the noctigons will need any filing before they fit (my sinkpads needed a little filing and finishing of the edges to fit into a 16mm pill).
On the other hand the Sinkpads are out now while my order of noctigons probably won’t arrive for a few weeks.
Both Sinkpads and Noctigons are probably a vast improvement over conventional thin aluminum boards.
Agree with all of the above. like I said I was only commenting on the Sinkpad as I used it. Not saying they are bad just thought the Noctigons look like they could be more user friendly. I think it didn’t help that the screening on mine was slightly faulty causing problems seating the LED.
Marc.
