17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc
Ok I found it, but sodering to the pins of the attiny makes flashing on the board complicated. So using the otc pad is for me the way to go I think.
But I am not sure with the otc pads, are they connected to pin2 (#define SWITCH_PIN PB3)?
I found this picture: 17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc
Is it necessary to leave c1 in place when i place a 10uF Cap on the zener place with a zener stacked on top?
Why is it better to replace R1 with 36K, the picture show a 22k resistor?
Thanks!
Which board revision are you building? You shouldn’t need two 10uF caps but I haven’t tried just one on wight’s board. I use RMM’s boards (from his MTN store) and you only place one 10uF.
The 36k resistor isn’t required if you already have a 22k. It just gives you more options with the ADC calculation for the LVP (low voltage protection). With the 22k and 2S (~8.4V) you end up being in the upper range of the ADC (limit of 255) with 6V LVP. If you wanted to have something higher for your LVP like 6.4V you would need the 36k resistor. You can see the calculations on RMM’s Google sheet that he so nicely shared with us before:
If you look, the 36k brings the ADC values more into the middle rather than the upper limit.
Ahh I understand. Then 36k seems to be very usefull! And the calculations, too :wink: Thanks!
I use this Layout (should be the same like in the picture here: 17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc):
OSH Park ~
I’am not sure now, if one cap 10uF is enough….
One 10uF should work. On the board you linked to, place the 10uF on the zener pads then stack the zener on top of the capacitor.
Thanks Richard! I will give it a try :wink:
The Zener direction is the same like printed on the layout? Cathode points to R2?
Yes, same as printed.
Works like a charm! Thanks
https://oshpark.com/shared_projects/OODIn7Cf
Can somebody confirm this as a working zener-layout? (no workaround)
Does anyone happen to know what could be causing one of these drivers to change modes on its own?
I made 50 of these last batch and they all work fine normally. I had even used one of them with an eswitch in the past and it was fine. However recently I tried using JohnnyCs dual switch firmware with them and this is what I get.
https://youtu.be/vw5rxIBh7_M
It will just sit there and skip upward in modes at random on its own. I tried multiple drivers and even assembled a brand new one and the result is exactly the same. I tried both 6 and 12v configs too with no luck.
I tried using the default firmware from JC and TomEs eswitch one and they both skipped. I had used toms before too and did not have this issue so the only thing I can think is that I was shipped a bad batch of components. Problem is I have no idea which part could cause this :(
Any one got an idea?
Hhmm. I watched the video 3X, not sure wut could be goin on. It seems very periodic and relatively slow, I think... What kind of setup to you have there? Think I saw 4 cells in series, so 16V going into the driver? Wow... With an e-switch, I assume you are using an LDO?
The pace seems like LVP is kicking in, but it's going up not down... But if it's acting like a click is happening, I suspect something unreliable bout the switch input, but you are grounding it manually. Dunno, I'm no expert there in electronics. Maybe the voltage the MCUU is getting? If so, maybe the LDO that supposed to regulate that voltage? Again, I'm not sure exactly how an LDO works, but it's supposed to deliver the correct voltage to the MCU. Maybe you can check that voltage level on the MCU VCC pin #8?
Is this still the preferred parts list for a 1S V044 board?
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=48a3801cb6
Thanks Matt
I've almost always only seen that happen when the driver is glitching due to a dirty VCC signal. How is your circuit set up?
By dirty VCC you mean like a trace that is too close to something else? By circuit setup you just mean a picture of the underlying traces right? If so I will try to do that tomorrow.
I also have one other pressing question if you don't mind.
I have tried to use firmware that has a strobe function with these drivers, and on both the 1 and 2 cell board the strobe and SOS sequences are very very slow. I have tried 2 different firmware's which I know to be good with 7135 boards and the result is the same.
Any idea why that might be?
When you're pulling high amps with an FET you can make the MCU glitch if the layout and components aren't just right.
About the SOS speed: there is no reason why the speed would be different on an FET driver than it would be on any other driver with the same MCU. Are you sure that you're flashing the same file and fuses?
Ya the firmware is the same and I tried it on like 5 boards. I know for sure the code is good to, its my Sport UI from DrJones.
I may pick up a few boards from you and try installing my components on that and see what happens. If all my problems go away then we will know where to look for the trouble.
I have been wondering if some drivers are too sensitive to RFI — it’s hard to test.
And with WiFi there’s plenty of radio noise around.
With the lens opening and wires from LED exposed there that could act like short little antennas, could electronic smog be a problem?
I’ve taken some dubious lights (LDCH-20 and LDCH-30 drivers with 1xNiMH) on long walks to see if their behavior jumping modes was any different.
Couldn’t really tell.
I suppose I could put them in a Faraday cage ….
I did not get an answer a few posts back and want to make sure before I order…
Thanks Matt
preferred? No.
compatible? Yes.
I recommend switching the 22k resistor to a 19.1k version. Other than that, most people have their own preferred FET model they think is best.
