Instead of the Keeppower 750mAh, take a look at these: Test/review of Keeppower 18350 1200mAh UH1835P (Black) 2017
The Keeppower UH1835P 1100mAh/1200mAh are equivalent to the famous Aspire 1100mAh cells, the best high-drain IMR 18350s.
The Shockli is also on the top, so you can’t go wrong with it!
You can compare both cells performance here, on HKJ comparator: Battery test-review 18650 comparator
