Sure it can when not protected. Also, what you are doing is dangerous. Just think what happens if one of the PCBs fails. ;)
V-Spec: He deep discharged them with a hobby charger before, so there wasnt really much energy left in it. Of course its not advisable to do so unless you know what you are doing..
1) Test and measure all the cells.
2) Don’t buy cheap crappy 18650s, always check battery reviews first when going to shop for batteries, there are some **Fire that don’t suck, like the TF 26650 Flame but that’s about it.
3) Get Sanyo UR18650FM or some type of Panasonic of your preference. The price is not that much higher compared to rubbish TFs, UFs, …
Indeed, that makes sense for two-cell lights. What about lights with more than two cells? I'm having a hard time imagining such stuff early in the morning. :D
Other even numbers can be used, but requires that the batteries has the same voltage, odd numbers is not a good idea. I will not recommend more than two batteries, because a mistake in orientation is bad.
Here I have draw the circuit, the red box is a resistor that simulated the head of the light.
As can be seen two and four batteries is just parallel. With four batteries you could also have 3 one way and one the other way, it would give the same problem as 3 batteries, just worse.
I don’t understand why am I still able to operate the 3T6 with the defective battery. I on it and it was definitely very very bright. Fortunately, it did not explode yesterday or else I will not be here today.
I still value my hand. I even kept it inside my new safe (which has nothing in it except the 18650). I figure if it explode, my house will be still intact.
