2-group Convoys - change to 1 group (permanently disable blink modes)?
Try these threads
I use an arduino and soic-8 clip instead of the usb progarmmer since I always have a bunch laying around. It’s a nuisance to set up the first time, but once you get everything figured out it can be a lot of fun getting exactly what you want
Edit: Forgot to mention you can also buy a 17mm replacement driver. I’d suggest QLITE REV.A 7135*8 3.04A LED DRIVER - 17mm
It should be almost identical, but with better firmware and slightly higher output
