Hmmm, I see what you’re saying and raise you these facts…
Indeed I shot at 28mm to show the beam profile. Figured the high definition pic would allow looking at the end zone. Not exactly considered wide angle, but a bit wider than what the eye sees.
Lights are pointed directly at the opposing goal post. They were in a carrier on top of a tripod. I adjusted the hot spot to center on the goal post before taking the 1st shot, then locked down the video plate on the tripod. The carrier is a split tube, with velcro wrapping around it to secure the light.
The only lights showing behind the goal post are at a building that is 264 yds away from that opposite goal post (about 380 yds from the C8’s). There were some lights to the right, at the field house. Was very dark, surprisingly so, I couldn’t believe the gates were open with no lights on. 9:30 at night, the light situation was better than I’d hoped for. Looked at 2 other towns football fields and couldn’t get easy access.
I raised the tripod carrier to a height of about 6’4” for these shots, had to lower it for the attempted side shots that didn’t turn out as my wife was running the lights and she’s only 5’ tall.
So, with the lights actually over my head and adjusted to hit the center of the vertical goal post at the opposite end of the field, not sure how I can keep them from appearing to point down. As the light travels and the hot spot grows, there will be more on the ground under the line of the beam. Unavoidable. At this point, they’re just not real suited for throw. Will be getting those 97 yd shots tonight, then de-doming tomorrow. Then we’ll see what kind of difference that makes. I know it typically drops lumens output, but tightens the beam. So it’ll be interesting to see what the final result is with power the same as it was for these, then bumped. After testing the de-doming, the plan is to stack 4 chips on each driver (12 total) then start over with the testing. Should be in the 4.4A neighborhood with losses accounted for. Depending on how the lights show up in the numbers, heat and such, I may add up to 4 more chips (16 total) to the ones that can take it.
Up to this point, with the possible exception of the copper pills, these are all set up pretty much as one would buy them, if all 3 emitters were available in a C8. Starting tomorrow, they go into “modded” territory.
