2x UF-1508's arrived, both broken. PICS AND 'COMMENTS' ADDED
One red, one white emitter.
Ordered the Cree XML…not sure if that was what was sent or not though.
Not measured LED current, but tail cap current with one cell is 1.25 amps and two cells 0.9 amps
I have not stripped open a white pill yet. I do not want to risk F…ing them up , till I have new stars and drivers for the red pills, which I bought only to strip apart and rebuild.
Star and driver both seem to be 17 mm…Could potentially be 16…not got the vernier out yet…this was just checked with a tape measure
Paper cover over the star
The red single power level driver. Ruby from UniquireFire tells me this driver is good for 3 series (12 volt). All their single mode drivers are good for 12 volt, where as the 3 mode drivers are only up to 2 series 8.4 volt
There is 8mm depth in the pill for the driver so drivers with bigger inductors would fit depth wise, but since the securing ring has a tight 8mm hole in it, any driver with components on that side will need to be well away from the edge to allow the driver securing ring to fit
The white driver is high/lower/ strobe. Talked about in this thread
Switch spring has brass block/pin, not connected in any way. I guess a solder bridge here and flex wire to the switch would help if I try and push the current.
Can remove the extension and run with a single 18650 is needed. I wonder if I can find a driver to run three or 4 x 18650’s I have enough extension tubes…I bought three of these 1508’s
Pill fully fitted…regular threading direction
Pill on first thread
As you can see the pill has groves around it and is not a tight fit in the housing….Well it is when fully tightened, but there is no, or very little heat transfer between the brass pill sides and the alloy housing. I guess you could fill with heat sink compound?
A big step and parallel section inside the head, but this could not be turned out on a lathe as the fins are cut too deep externally. I was wondering about this as I though maybe this step is helping cause the rings in the beam pattern?
Screwed in just enough… for max zoom position.Slightly longer would be better. Might be possible to machine the pill to seat a bit deeper, and machine the bezel allow the lens to sit further away.but only by I guess a max of 1-2mm.
It would be possible machine off two of the fins in the pic below, between the tweeters, to allow the head to be screwed in further towards the LED to give a better flood which is very poor.
I bought two of these identical . Pictured here, one on Max zoom and one on max flood.
I do have a third one on order from a local UK supplier…but it has not arrived yet… 4 days for two to arrive from Chine, and over 10 days now and the one I ordered from Amazon UK has still not arrived!
