3A+ Buck Boost Driver Size?
Single board, double sided, might be possible if no battery spring pad, but I think that would defeat the purpose?
Now that I know the depth of the ledge of the P60 pill, I see that there are other inductor candidates that would work with less height. A Nanjg 105C is 4.8mm in height excluding the spring, with a two board solution, maybe 8mm at best.
My 1A buck boost boards are coming in the mail, so lots to do on that for the time being.
If I wanted to use a buck driver, I’d just use a buck driver :slight_smile: This is more to drive a 2S (or 3S) LED light with an equal no. of series li-ion cells, but without the large power losses you get in a linear driver or the dimming you get with a buck driver in this set up as Vin drops below Vf+overhead. Not a common requirement, but it’s what I’m interested in.
I dont use Li-Ion cells so would love a driver that could slightly boost 3 x C or D NiMH cells just enough to allow a longer “regulated” output at 3A using emitters with high Vf, especially now that the XM-L2 is starting to become available.
…or a buck driver to allow 4 NiMH cells to be used to increase the regulated run time without just burning most of the fourth cell off as heat, like linear drivers do. There are heaps of 4 cell lights (eg JetBeam PA40, Fenix TK70, NiteCore EA4) so it must be possible!
