They’re back, I shot these pics the other day as I did a quick walk through my nearest Costco. When I am out that way I always do that as it isn’t often that I get a chance to visit there.
Last time they had these I passed on them and when they ran out regretted that I didn’t get one. Funny thing is, now that they are back, I passed on them again! I now regret that too, I need to replace the innards of a 4’ florescent kitchen ceiling fixture. The tenant is complaining that it “hums”
Sorry about the last pic, I used the “pano” function on my new iPhone and I didn’t pan smoothly enough for the phone to stitch the picture correctly. LASTS 45 YEARS!
ROFLOL!
45 years?
it is possible but highly improbable .
some of mine are older than that.one in my bedroom is from 1946!and i trust its safety over that cheap led thing anyday.
I bought some of those 60 watt LED bulbs from Lowes for $6.97 a while back…they too have a slight delay when you flick the switch on, maybe a few tenths of a second…but definitely a slight delay (but no flickering)
We bought 50+ of these “LED Shop Lights” and replaced all of the fluorescent tubes in the office with the hopes that they will last longer without needing bulbs or ballasts to be replaced.
I strongly suspect that there will still be a ballast to eventually change out, if you got this same kind, since it appears to just be using off-the-shelf LED replacement tubes, which were made to directly replace fluorescent tubes in a working fixture.
my guess is its a cheap capacitive ballast driving a full wave bridge with a cap to knock the ripple and thus the flicker down.
most gensets will run it ok but squarewave inverters might damage it.
its going to be a very cheap n nasty thing.i saw one at the flea market a few weeks back and its color rendering was poor.
definatly optimised to look bright with that big green spike in the spectrum.
i will pass……
I had to create an account. Bought 4 of these yesterday. The first thing I did was take one apart. They’re basically a led light strip in each acrylic tube with the electronics for each at the beginning and end. So you can separate them if you want. Forget “tubes” and “ballast”, the tube is only there to diffuse the light, it’s plastic, and when you unclip the electronics the led strip slides right out. They’re on sale for $32 right now. Seemed a good price for what you get. Thinking about making valance style lighting in the kitchen with a few, using an old vacuum cleaner cord instead of the 6’ one supplied.
Whird is right, these shop lights at Costco have been reduced to $32.
I finally picked one up yesterday. I brought it home, plugged it in and it ran for about 5 seconds and ……………………
……………… then I unplugged it and decided to take it apart.
The deflector simply clamps onto the 2 tubes, but those tubes are not replaceable bulbs. This light is simply 2 sets of strip lights configured to look like a florescent light fixture.
That’s OK for me as I don’t expect to ever have to replace anything. It is supposed to last 45 years, LOL, and even so it is a “throw away”
In the fixture there are 2 sets of driver circuits driving the 2 LED strips. Whird mentioned this, and I confirmed it. The LED strips seem to be driven on BOTH ends, ala our conversations over at this post by texaspyro
Here is a pic of the power supply board at the plug end of the light.
Bottom of the board, looks like a full wave bridge? and some current limiting resistors?
Top of the power supply board, plug end of the light.
There are 60 LEDs in each of the 2 Aluminum strips and they simply slide into a track in the tube which is clear on the side facing downwards and white on the other.
I didn’t check each LED, but they all seem to be wired in series, all 60 of them.
This is the driver board at the OPPOSITE end of the strip, top and bottom of the board.
There are 2 sets of these power supply and driver boards, 1 for each strip.
This fixture is rated at 3700 lumen and without being able to confirm it, I am ready to believe it. It puts out a lot of light and I am satisfied with it.
BTW, I didn’t have time to take any voltage readings as I was in a hurry to watch the Super Bowl.
I hope that is excuse enough for not being as thorough as I should have been.
This is a manufacturers instant rebate, not a Costco price reduction so I would expect it to be reduced at all Costcos that have them.
EDIT: Now I wish I spent more time while I had the light apart. IF all 60 LEDs in each strip ARE in series, then I don’t see an advantage in driving the strip at both ends. I am thinking the driver was split from the power supply and placed at the opposite ends for space and perhaps heat considerations.
Since it looks like at least one of you have taken one apart, think it would be easy to disconnect the power cable and wire it in where my current fluorescent fixture is?
It would be rather easy, BUT, we are talking high voltages here and it is dangerous. Is your original fixture wired in place? Unless you really know what you are doing and are qualified, I don’t think you should attempt that.
There’s a discussion on that question around here somewhere from a few months ago, and it gets seriously mathematical fairly fast.
I think the short answer is, it works better.
That’s right, it does work better in that instance. That was a case were every 3 LEDs were in series, then each set of 3 were in parallel with other sets of 3S. In that case it was better. If however, and I now wish I spent more time in the tear down, all LEDs are wired in series, there is only the 1 option of driving them at both ends.
I probably should take this light apart again and go over it more carefully.
I haven’t seen the other discussion, but one advantage I can guess would be that the traces can be thinner/smaller, because they don’t have to carry all the current for the 60 LED’s from one end of the strip to the other. Also, the drivers themselves can be smaller and/or lower rated since they are splitting the load.
That may be, but those T8HO bulbs you speak of go for about $20 each and can not be retrofitted into ordinary T8 fixtures. They need special HO fixtures and ballasts, I have some of those HO fixtures in a commercial building and they are bright, but they do not last.
This light certainly may not be able to replace them, but they may be able to replace ordinary T8 fixtures where a twin bulb fixture typically puts out around 5600 lumens - when new and everything is working correctly. And a cold start fixture costs way more than these. I truly see a huge advantage in the future for LED shop fixtures.
