TIR with glass
. So Saimon fixing like this ; TIR+glass + fat gasket.
Seems like both 219b and c still available on Aliexpress HERE ?
I have H2 with 219b 4500k & 3500k and B35AM. All 3 have throwy beams btw so, for me, better as walk light, as opposed to light for close-up work. The 219b 4500k has beautiful rosy beam if thatās what youāre looking for.
Itās what he does with S21E as well⦠He only added the 23.5mm Yajiamei that fit S21E without a front glass after I randomly found them in the Yajiamei store, ordered some and told him that they fit.
I really donāt like TIR behind glass, unless itās a smooth throwy TIR. But pebbled TIR behind glass⦠Nah.
The 23.5 Yajiamei fit perfectly, but that obviously doesnāt help with the H1.
I just spotted that the 60° TIR is available as an option when purchasing the H1 on the Convoy store ā so it seems Simon does offer a TIR setup officially.
I think I read last night that thereās a copper shim used to make up the height difference when replacing the reflector. Iāll try to find that source again and report back once I do.
Is this the mentioned lens: 23.5mm TIR lens for 3535 LED ?
Do you use it with 5050 LED or 3535 ?
Iām by no means a driver expert but I was under the impression that you can still have a regulated linear driver, until it drops below the voltage of regulation then is essentially direct drive.
I bought it with reflector. There was no spacer. I had to make my self. On official site there is no damn info or spacers to buy .
Anyway it is heavy and need that damn spacer to use TIR optic ⦠but yea x2 cheaper than H04.
Yes, it only fits 3535 and (if you donāt mind it scraping a bit on the edges of the emitter) B35AM.
I am using it for 5050, by using a 5050 gasket as a spacer, and filing the bottom part off the TIR. Works, but itās a bit risky. I damaged my XHP50.3 already when I used a too thin gasket.
