Thanks for the review. As per the original post - for the price it cannot be beaten!
Hello,
Can I use Panasonic NCR18650A 3100mAH 6.2A with Convoy S2+/C8+ SST 40?
Hi…welcome to BLF!
Yes, you could use that cell and be ok. On 100% it will stress the cell a little bit with the standard 5amp driver but it will still be safe and will run ok…may see the light output drop off faster and the heat buildup may be a little faster as well. If you can use a newer 18650 with a little more oomph that would be better.
I haven’t looked at his S2 offerings lately but he usually has several options available. Stick with the 5A-ish driver or lower. He has an 8A driver that would be a little too taking on this cell (he only uses that driver in some lights with emitters that can handle it).
Hi, thanks!
Aliexpress seller told me that SST 40 is 5A max and I’m not consider using it on 100%…
