I have a few lights with them, and they’re a nice compromise for single-emitter, but I like this set-up better than the triple and quad 219c lights I’ve had.
Good tip. I was literally wandering around the house looking for clear flexible things, and I settled on a ziploc bag. I need to go find some clear-ish latex gloves, all i have is blue nitrile.
There isn’t really much to take a beamshot of, it looks like just about any other light
I could, but I don’t currently have it programmed that way. I wanted full amperage going to the XP-L’s in Turbo because they give a higher lumen/watt ratio.
I think you should get more light OTF with the Nichia engaged along with the XP-L’s, because of efficiencies. Maybe I’m wrong. I’ve never built a triple before myself.
You could be right. I’m not really sure how it would behave with both regulation and FET going at the same time.
In my head this is what I’m thinking (using djozz graphs): If my battery is supplying 8 amps, 4 amps to each XP-L, that gives me ~1400 each or 2800 total lumens. If I split 3 amps to each XP-L and 2 amps to the Nichia, that gives me 500 for the Nichia, and ~1125 for each XP-L or 2750 total lumens. So if it behaves the way I think it would, it should be very very close in output.
I’m already planning to do an almost complete overhaul of this light, so I’ll play with some things at that point. I don’t have a way to measure lumens though, so IDK how much good it would do.
Hmm I suppose battery sag would be the same but Vf on the XP-L’s would be a little lower, so you’re probably right.
I’ll have to try it and see how I like the beam profile. I’m not sure how noticeable the tint differences would be or if maybe the frost on the optic would blend them.
