icpart
(icpart)
June 27, 2022, 5:02pm
19
Fattious:
Cheers, all the brackets I have on the ““Stonker product page”:Shop Stonker eScooter Headlight Series by eScootNow ” are sourced from Aliexpress. I have a pretty extensive holding of bolts, nuts, washers and T-gaskets depending on the mount and where the headlight is to be mounted. More details on the brackets are on the linked bracket product page. I’ve tried not to yabber on too much on the product page, but there are some additional application considerations amongst the various brackets. The type A bracket requires a bit of cloth tape (or similar) over the bar to make it’s positioning more firm and the thick rubber on the mount around the bar provides ability for the rider to adjust the mount as required without tooling. The type G bracket for example has no rubber, and is totally fixed. I prefer A as sometimes on open road riding with minimal oncoming traffic I like it facing up, but ideally StVZO lens would negate that requirement.
Thanks for explanation. Can you give to us more information about your bike light project https://escootnow.com.au/products/Stonker-eScooter-Fixed-Headlight-Series-by-eScootNow-p466806813
It is very cheap compared to Magicshine 8000. Also what are there specs of “XML-T6” and 8000 lumens? Here in BLF we associated XML-T6 with cheap chinese Cree fake leds.
