A17DD-L Drawing Only 2.75a?
Thanks for the reply bud, a lot of good info there.
The switch PCB was a definite bottleneck, which is why it failed when I accidentally shorted the emitter POS to the reflector. The OshPark board is 17mm, I’ll see if there is a 20mm which would be compatible with my tailcap.
The springs were bypassed internally, and I haven’t had one like that fail before, but I may give double springs a go with the new switch/driver.
I am using solid core household wiring in my clamp meter at the moment, less ideal than stranded heavy-gauge wire, but it was all I had on hand.
I hope to get this light up and running again in the next week and see if any tweaks pull more amps, I’m aiming for 4.75a as a guess, I think this LED will go about 6a, but gives no more output above 5a.
