For the record, my white E10 measures 540 lumen and 125kcd (almost full battery and 30+ seconds). Pretty weird how far off the specs it is, output way lower and throw way higher.
Thanks djozz for adding your data point. It seems the light is producing numbers in a range that is appropriate for the dimensions. I agree that it’s perplexing how a manufacturer like Acebeam could be so far off. Dumb, really.
Interesting light.
Anybody know if there is a 26650 or 21700 tube that fits this?
I could use my current stash of batts. And get way longer runtimes.
Akk the Best,
Jeff
There is the L17 which uses the same optic and also the Astrolux EA01 which might interest you
The Astrolux EA01 battery tube does not fit the Acebeam E10 head, the Astrolux FT03 battery tube does not fit, but the battery tube from a first gen. Sofirn SP33 that I have does fit, it threads in very loosely but once fastened it feels solid and works well.
The Fireflies T1R will be available with 21700 tube, and appears to use the same or similar TIR. May be worth a look.
