I’ve never seen a bare 12v or 6v mcpcb… based on the picture above, what indicates visually that it is either 12v or 6v ? I have a flashlight in either one of those and I’d like to examine it.
I am a huge MTG-02 fan, but this one has converted me! The output of the 4500k in the S11 is so creamy that it is almost dreamy. It also has a much better hot spot since it has no dome.
I am think of converting my Haikelite’s but I am not sure if they are 12V on not, have not torn into them that far… Did the MT-G2 only come in 12V… I think so! I still do love the old workhorses… I did make a P60 drop in once with a 4000k MT-G2 and loved it… will have to dig it out again as well.
I made some color test lighting set of thinks with different light sources:
Sun light in room with neutral color walls and ceiling.
SST40 5000k LED in convoy flashlight. Battery current (LED has consume same) was around 2A.
SST20 4000K LED in convoy flashlight. Battery current (LED has consume same) was 1.75A.
LH351D 4000K LED in sofirn HS05 flashlight. Battery current (LED has consume same) was around 2.3A.
GT-FC40 4000-4500K LED in convoy S11. Battery current (LED current is unknown) was around 3.2A.
White balance was automatic. There is next post with WB fixed to day light.
All flashlights have different light beams.
So try to not notice to light level, shadows, color temperature.
Just notice to color differentiation into each scene. Are the colors distinguishable?
"SST40 5000k LED in convoy flashlight. Battery current (LED has consume same) was around 2A.
3. SST20 4000K LED in convoy flashlight. Battery current (LED has consume same) was 1.75A.
4. LH351D 4000K LED in sofirn HS05 flashlight. Battery current (LED has consume same) was around 2.3A.
5. GT-FC40 4000-4500K LED in convoy S11. Battery current (LED current is unknown) was around 3.2A."
But I missed a table containing XPL Hi, XHP70.2/3, random Nichia, random OSRAM, perhaps others.
I definitely missed at what level those current readings were taken. I'll reread, because I assumed they were all on low, given the photos.
