OCTOBER 8, 2026 UPDATE
ALIEXPRESS OCTOBER 2026 COUPON CODES
The main active AliExpress coupon campaigns currently available are:
Global Coupon Codes | ACTIVE
USA Exclusive Coupon Codes | ACTIVE
USA New User Coupon Codes | ACTIVE
Brand Day | UPCOMING October 9
Winter Offers | UPCOMING October 14
This thread will continue to be updated as new AliExpress October promotions and coupon codes become available.
GLOBAL ALIEXPRESS COUPON CODES | OCTOBER 2026
ACTIVE NOW
Currently active
Scheduled through: November 1, 2026
| Minimum Spend |
Discount |
Global Code |
| $29+ |
$3 OFF |
IFP33UJR |
| $59+ |
$6 OFF |
IFPYRTRE |
| $89+ |
$9 OFF |
IFPYLWGV |
| $149+ |
$16 OFF |
IFPSNXYG |
| $199+ |
$23 OFF |
IFPJTMB5 |
| $269+ |
$30 OFF |
IFPFQWIG |
| $369+ |
$40 OFF |
IFPQKDJY |
| $469+ |
$50 OFF |
IFP60OSW |
| $599+ |
$60 OFF |
IFPYIH2N |
| $699+ |
$70 OFF |
IFPRNIUA |
Use the strongest eligible Global coupon matching your cart amount.
Before increasing your order to reach another tier, compare the extra amount you would spend against the additional discount.
USA EXCLUSIVE OCTOBER COUPON CODES
USA ONLY
Valid: October 1 to October 31, 2026 | ET
Higher USA-specific discount tiers
Save up to approximately 14% to 15%, depending on the tier.
| Minimum Spend |
Discount |
USA Code |
| $15+ |
$2 OFF |
IFPE5ECN |
| $35+ |
$5 OFF |
IFPL6DFH |
| $65+ |
$9 OFF |
IFPCCTSB |
| $99+ |
$14 OFF |
IFPFQBQA |
| $169+ |
$23 OFF |
IFPYEXAS |
| $279+ |
$40 OFF |
IFPSRCJA |
| $379+ |
$55 OFF |
IFPE7EAD |
| $559+ |
$80 OFF |
IFPT2BOS |
USA NEW USER EXCLUSIVE CODES
FIRST ALIEXPRESS ORDER | USA ONLY
These codes are specifically intended for eligible new AliExpress users in the United States.
If you are opening a new account or placing your first eligible AliExpress order, test these before using the regular USA or Global coupon tiers.
| Minimum Spend |
Discount |
New User USA Code |
| $10+ |
$3 OFF |
XC3OFF |
| $20+ |
$5 OFF |
XC5OFF |
| $80+ |
$12 OFF |
XC12OFF |
For smaller carts, these new-user offers can be considerably stronger than the regular coupon thresholds.
Example:
$20 new-user cart
XC5OFF
= $5 OFF $20+
That can be considerably stronger than increasing your cart simply to reach another coupon threshold.
New-user eligibility is determined by AliExpress.
Existing accounts should use the regular USA Exclusive or Global codes.
WHICH USA COUPON SHOULD I TEST?
If you are shopping from the United States, compare every campaign your account is eligible for.
NEW USA USER
Test:
USA New User Code
β
Compare with any other offer AliExpress makes available to your account.
β
Check:
Coins + Seller Coupon + Other Eligible Discounts
EXISTING USA USER
Test:
USA Exclusive Code
β
Compare with:
Global Code
β
Check:
β
Use whichever eligible coupon produces the lowest final checkout total.
WHICH COUPON SHOULD I USE?
AliExpress generally allows only one main platform promo code per order.
That means you normally cannot combine several AliExpress platform promo codes together on the same checkout.
Instead, compare the eligible campaigns.
GLOBAL SHOPPER
Test:
Strongest Global Code Matching Your Cart
β
Then check:
β
Compare the final checkout total before paying.
USA SHOPPER
NEW USER
Test:
New User USA Exclusive
XC3OFF | XC5OFF | XC12OFF
β
Compare any other eligible promotion shown on your account.
β
Check:
EXISTING USER
Test:
USA Exclusive Code
β
Compare with:
Global Code
β
Use whichever eligible option gives you the lowest final checkout total.
XPRESSCOUPON STACKING METHOD
The promo code is only one part of the final AliExpress price.
A strong October order can potentially combine several different discount layers:
Sale Price
AliExpress Coins
Seller / Store Coupon
Best Eligible AliExpress Promo Code
Payment Offer if Available
LOWER FINAL CHECKOUT PRICE
THE GOAL
Do not focus only on:
Which coupon has the biggest number?
Focus on:
LOWEST FINAL CHECKOUT TOTAL
A larger coupon does not automatically mean the best deal if you must add unnecessary products just to reach the threshold.
For new USA users especially, check the low-threshold codes first.
For example:
XC5OFF
provides $5 OFF $20+
while regular coupon campaigns may require a substantially larger cart before reaching a similar discount.
ALIEXPRESS COINS
AliExpress Coins savings can vary depending on:
- Product
- Country
- Account
- Coins balance
- Promotion
- Product eligibility
- How the product page was opened
Always compare the actual reduction shown at checkout.
Coins can also be useful when a promo-code allocation is exhausted.
When compatible, Coins can potentially be used alongside an eligible promo code rather than only as an alternative.
SELLER / STORE COUPONS
Before checkout, check the product and store page for:
- Seller Coupon
- Store Coupon
- Get Coupon
- Store Discount
- Automatic Product Discount
Seller-level discounts may sometimes work alongside the main AliExpress promo code.
CHECK THE NEXT COUPON THRESHOLD
Before paying, check how close your cart is to the next tier.
Example:
Your Global-code cart is:
$145
The next Global tier is:
$149 β $16 OFF
You are only:
$4 away
If adding something you already need produces a lower final effective cost, reaching the next tier may make sense.
Do not buy unnecessary products simply to unlock a larger coupon.
Always compare:
Extra Spend | Additional Discount | Final Cost
FIND MY BEST CODE
Instead of manually calculating every coupon tier, use:
Find My Best Code
Enter:
- Your country
- Your cart amount
The tool can help identify the strongest coupon tier matching your order.
Find My Best Code
XPRESSCOUPON STACK CALCULATOR
Use the XpressCoupon Stack Calculator to estimate combined savings from:
Coins Discount
Seller Coupon
XpressCoupon.com
XPRESSCOINSBOT
If a coupon is out of allocation, or even when your promo code is already working, do not ignore AliExpress Coins.
XpressCoinsBot can help check whether the same AliExpress product may have a stronger Coins opportunity.
Coins can be part of the stacking strategy, not only a backup when coupons fail.
Always verify:
- Seller
- Product configuration
- Product price
- Coins reduction
- Final checkout total
XPRESSDEALS LIVE
XpressDeals Live helps identify discounted AliExpress products before applying additional savings.
Deals can include:
- Current Price
- Original Price
- Discount Percentage
- Rating
- Number of Sales
- Product Link
- Additional Saving Opportunities
Starting with a strongly discounted product and then adding eligible coupon and Coins savings can produce a better final result.
XpressCoupon.com
XPRESSCOUPON CHROME EXTENSION
If you shop AliExpress from desktop, the XpressCoupon Chrome Extension provides quicker access to coupon information and XpressCoupon tools while browsing.
XpressCoupon.com
ALIEXPRESS COUPON CODE NOT WORKING?
Check these before giving up:
- Is the coupon campaign active?
- Is your eligible subtotal high enough?
- Is the coupon available in your country?
- Is the product eligible?
- Has the coupon allocation run out?
- Have you already used the coupon?
- Is another platform promo code already applied?
- Has the coupon expired?
- Does your account qualify?
- Did you compare the regular Global code?
- If you are in the USA, did you test the USA Exclusive code?
- If you are a new USA shopper, did you test
XC3OFF, XC5OFF or XC12OFF?
- Is your AliExpress account actually eligible for a new-user promotion?
GLOBAL CODE TROUBLESHOOTING
If a Global code fails:
- Confirm that your eligible subtotal reaches the required threshold.
- Check whether the code is available for your country.
- Verify that your products qualify.
- Confirm another platform promo code is not already applied.
- Check whether the coupon allocation has been exhausted.
- Try the code directly at checkout.
- If you are in the USA, compare the corresponding USA Exclusive tier.
Always compare the final checkout price rather than only the headline coupon value.
USA NEW USER TROUBLESHOOTING
If you are a new USA AliExpress shopper:
$10+ cart
Try:
XC3OFF
$20+ cart
Try:
XC5OFF
$80+ cart
Try:
XC12OFF
If AliExpress rejects the code even though you meet the spending requirement, your account may not qualify as a new user or the items in your cart may not be eligible.
Always check the exact error shown at checkout.
REPORT WORKING OR FAILED CODES
Help keep this October thread accurate.
Comment using:
Country: USA / Canada / UK / Germany / France / Spain / Italy / Australia / Japan / Other
Cart: $___
Code: ________
Result:
Working /
Failed
Account: New User / Existing User
Error message: If applicable
Examples:
USA | $20 | XC5OFF | New User | β
Working
USA | $85 | XC12OFF | New User | β
Working
Canada | $165 | IFPSNXYG | Existing User | β
Working
USA | $170 | IFPYEXAS | Existing User | β
Working
UK | $245 | IFPJTMB5 | Existing User | β
Working
Germany | $360 | IFPFQWIG | Existing User | β Failed
USA | $570 | IFPT2BOS | Existing User | β
Working
Community reports help identify which codes still have allocation and which markets or accounts are eligible.
COMPLETE XPRESSCOUPON TOOLKIT
XpressCoupon.com
Current AliExpress coupons and sale information
Find My Best Code
Matches your country and cart amount to coupon tiers
XpressCoinsBot
Checks product links for stronger Coins opportunities
Stack Calculator
Helps calculate discount combinations
XpressDeals Live
Finds discounted AliExpress products
Chrome Extension
Quick access to coupons and tools
Sale Calendar
Tracks current and upcoming promotions
Stacking Guide
Explains compatible discount layers
Telegram Alerts
Coupon drops, replenishments and deal updates
r/XpressCoupons
Community reports and coupon discussions
OCTOBER 2026 PROMOTION STATUS
October 9 to October 11
New promotional offers and codes will be added when available.
If AliExpress releases limited coupon allocations at the start of the promotion, collect and test them as soon as they drop.
The first 30 minutes can be important for high-value coupon tiers with limited allocation.
October 14 to October 16
Additional promotion details and coupon information will be added when available.
GLOBAL COUPON CAMPAIGN | ACTIVE NOW
Scheduled through November 1
Regular Global codes are already active.
Use the strongest eligible tier your cart qualifies for.
USA EXCLUSIVE COUPONS | ACTIVE
Regular USA-only coupon tiers:
$2 OFF $15 β $80 OFF $559
USA NEW USER COUPONS | ACTIVE
For eligible new USA AliExpress users:
$3 OFF $10+ | XC3OFF
$5 OFF $20+ | XC5OFF
$12 OFF $80+ | XC12OFF
These are new-user-specific offers and are separate from the standard USA Exclusive coupon campaign.
SHOPPING ON OCTOBER 8?
Before paying:
Know your coupon threshold
Test the strongest code matching your cart
Compare the regular Global code
Existing USA shoppers should compare the USA Exclusive code
New USA shoppers should test XC3OFF, XC5OFF or XC12OFF
Check Seller Coupons
Check Coins
Then compare:
Sale Price
Coins
Seller Coupon
Best Working Promo Code
LOWEST FINAL CHECKOUT PRICE
NEED THE BEST CODE FOR YOUR CART?
Post:
Country | Cart Total | New or Existing User | Product Category
Examples:
USA | $20 | New User | Electronics
USA | $85 | New User | Home
USA | $180 | Existing User | Flashlights
Canada | $250 | Existing User | Electronics
UK | $160 | Existing User | Tools
Germany | $95 | Existing User | Outdoor
France | $470 | Existing User | Electronics
Then after testing a code, report:
Country | Cart Total | Code | Working / Failed
I will keep the thread updated throughout October as coupon availability changes.
