There is an import ban in the UK for this model because of a wrong fuse (they have a mandatory fuse in the plugs due to the design of their electrical system). It also appears that not all parts are earthed properly and the isolation is always russian roulette with such devices.
Specifically the 200x200mm or also the 150x150 and 100x100mm?
True and I’m always aware of it with Chinese devices like this. I normally check them for obvious faults or risks (and correct them if possible) and handle them as carefull and as little as I can, the few times I use them in a year. Absolutely not a guarantee to stay safe, but for the limited use it’s a risk I consciously take.
(But if I don’t trust a device, beeing it that I see obvious safety risks or I have a bad feeling about its quality, then I won’t use it and discard it.)
Absolutely true and it’s cheaper too. I bought mine on Aliexpress for € 18,50 (shipping included). Mainly was an impulse buy, but it turned out to be extremely welcome for that very big and heavy copper MCPCB. There was no way that my old (and small) hot plate would ever be able to handle that one.
I might open it up/do a teardown (with photos) in the future, when I (finally) have the time again to do things like that.
I couldn’t help myself and ordered one for that price. I already have a Q8 Plus, which I’ve been wanting to mod for a long time, but (so far) I couldn’t get myself to take apart a perfectly fine flashlight, remove 6 perfectly fine XHP50’s (and probably never use them again) to swap in 6 other LED’s.
For this price, I have an affordable 2nd Q8 Plus to experiment with and mod it, while keeping my OG Q8+ stock. Since I already have new/better FETS (originally intended for my first Q8), I’m also willing to try this 2nd one with some of the really powerful tabless 21700 and see if the original FETS (and/or LED’s) will survive them!
EDIT:
Just for comparisson: I just checked and I bought my first Q8 Plus roughly 2 years ago for € 55,63 (without batteries), which was a pretty good price back then. I now paid € 42,69 and that is WITH batteries included!
(I’m going to swap them for more powerful batteries anyway, but 3x 5000mAh 21700 still represent some extra value and can be used in other lights.)
The AliExpress site was using the browser’s WebAudio API to run invisible sound waves at zero volume.
By measuring tiny hardware differences in how each PC processed those signals,
the site created a unique digital fingerprint to track devices – without user knowledge or consent.
I’m absolutely not surprised at this dubious behaviour. I have no doubts there are also western companies also operating data harvesting operations, so I’d prefer to view this as criticism of corporations Vs countries.
My next phone will be de-googled and I’ll likely find an alternative to AliExpress.
" The issue only surfaced after a developer had trouble using multipoint Bluetooth headphones while an AliExpress tab was open: the headphones wouldn’t switch properly from the computer to a phone. Once the tab was closed, the problem disappeared.
Digging into the site’s code, the developer found it was using the Web Audio API to build audio-processing graphs set to zero volume. The process produced no audible sound, but it still connected to the computer’s audio system, keeping the audio path active in the background, which appears to be what interfered with the headphones’ ability to switch devices.
This wasn’t the kind of audio activity tied to a normal media player. Because the processing graph ran at zero gain and connected directly to the system’s audio output, muting the browser tab did nothing to stop it: the browser kept processing the signal even though there was nothing to hear.
