I modded one for a fellow BLFâer (emitter swap) and was impressed with how compact it is (Iâm a minimalist and love small things). So I noticed the sale (runs thru Aug 2nd?) and had to pick one up. This will get an emitter swap. Stock UI looks decent but I might see about D4 V2 UI or Anduril for giggles.
If anyone needs a Nimh AA or AAA charger with lots of bays, there is a EBL 16 slot charger on sale with a $6 off amazon code.
Vipon also has a code that if applied takes the total to $8.49 before tax. The original price is supposed to be $32.99 and vipon gives you 50% off, $16.50 off but the charger is on sale for $28.99 plus the $6 off amazon coupon. This deal is probably a scew up and will not last long. https://www.vipon.com/product/7701118-EBL https://www.amazon.com/dp/B08C2GX7ZV?
I have no clue if its any good, just seemed like a good deal.
Awesome, Thank you gchart. Would you mind update on the mod (emitter, lens,etc.) I am also planing to mod my W1 since the stock is quite bad. I cant decide which one to choose from SSt-20 4000k, LH351D. Also may be a TIR lens since I dont like the tight beam pattern.
It kinda depends on what youâre going for. SST-20 will have more throw, LH351D will be more flood. Itâs also available in 90CRI 5000K which the SST isnât (only 4000K and under). Since you donât want a tight beam Iâd say LH351D unless youâre looking for a high R9 value.
Got mine over the weekend. The following day I tore it down and mapped out the circuit board for a potential brain transplant. But honestly I think the UI is good enough, I might just swap the LED and put âer back together.
