Got the tweezers thanks
Ordered a set as well. Thanks Ledhead!
Water guns - 2 for $1.80
Thatās really decent. Itās ending about midnight EST. Last time I had looked at the A1, about a year ago, it was $24.95. Kevin sure loves those XP-G3 emitters⦠uses 'em in so many Aurora lights.
āTodayās coupon code has run out.ā Original price of $17.99 made that $1.80 a really sweet deal. No wonder why it sold so fast.
Kevin sure loves those XP-G3 emitters⦠uses āem in so many Aurora lights.
That makes me so sad.
Bluetooth headphones $10
https://www.myvipon.com/product/8857894-Active-Noise-Cancelling-Headphones-with-45Hrs-amazon-coupons
https://www.amazon.com/dp/B09C8K3F4C
These appear to be rebranded Mpow H17 headphones.
I keep missing the Vipon coupon for these. By the time I wake up in the morning itās all gone for the day. Gonna have to set an alarm for 1:30 am my time.
will34:
Vipon buying spree of the day:
2 pack Motion sensor LED light for $15. The brand is reputable and seems like they want to push sales for this new item.
Appears to be using an internal 18650 due to the rectangular body, and if so they should be able to be upgraded. The main problem with the flat ones are the internal lipo battery, they are just designed to fail within a few months.
Thanks for the heads up. Just purchased these under counter LED lights. My wife has been asking for LED lighting just like this.
She wanted them for a closet and one under a counter in the kitchen. Iām sure sheāll be happy when they arrive.
Is there a sensitivity adjustment for the motion detector?
Richie086:
will34:
She wanted them for a closet and one under a counter in the kitchen. Iām sure sheāll be happy when they arrive.Is there a sensitivity adjustment for the motion detector?
Our order has not arrived yet for another few days. Iāll be sure to post an answer to your question as soon as we test them out.
Doubt it. The bigger pyro modules have trimpots to be able to adjust things like that, but the smaller ones are more āintegratedā and are preset.
FlashPilot:
Richie086:
will34:
Edit: Just noticed in the photos it shows 6x cells which makes a 20,000mAh powerbank not 26,800mAh, but in the descriptions it claims it uses 21700? which according to this you might receive the 8x 18650 version or the 6x 21700 version POWERADD EnergyCell Series Power Bank, Power Your Devices ā Poweradd
Poweradd is a well known charger & powerbank brand but something must have happened because seems like theyāre pulling all of their products off amazon and selling them cheap under energycell store. I do remember they have been offering free stuff for positive reviews in the past, maybe same fate as tacklife?
Anyways $13.59 for a 26,800mAh powerbank with 30W PD charging is a steal, well that IF you get the real poweradd product. There is also a 15,000mAh version for $10.
Just received both of these power banks. Both arrived in brand new unopened boxes and are each about 1/3 charged. I have them on the charger now and Iāll run
them through a charge cycle and let you all know if any issues arise. Thus far, all seems perfect, but I will try to open the larger 30,000mAh version and see what
type of cells are inside it.Thanks Richie. Im looking forward to your discharge results and 30k tear-down. Does the larger one allow for fast charging the pack? And can the pack be charged via USB C?
Iām charging the 30,000mAh PowerAdd from my large AFTIME power bank that I also recently received from Amazon. The AFTIME is sending the PowerADD 5.02v and 1.92a using
one of my USB-A to USB-C cables.
Mine is labeled 26,800 mAh, both in the instructions and on the power bank. How is yours labeled?
You are getting about 9.6 watts charging your bank using your current setup. I charged mine using a Pixel phone charger with the Pixel supplied USB-C to USB-C cable and get 18.4 watts charging the bank. It maintains that through most of the charge cycle then tapers down to about 4W before termination.
I cant be sure if the charger is authentic and I would rate the build quality as average.
Were you able to crack yours open yet or measure capacity?
I made a mistake itās labeled 26,800mAh just like yours. I havenāt been able to get one of the ends off yet, but still trying without damaging it. But I was able to recharge it fully using
a Knofarm 48 watt USB-C wall charger. The power bank required 107 watt hours of power to top off at almost 4 hours of charging.
Whaddya do wittit?
you do free things.
Whaddya do wittit?
You cutty cutty stuff
Whaddya do wittit?
Box cutter. Get one to open your Amazon packages!
One of those weird-reverse-angle thingies like seatbelt-cutters? Feh. Got my go,comma/PFknockoff for that.
pumpkin spice for $7
with code GFBXBB99.
