I got lost about halfway through all these posts about UV lights killing bacteria. :bigsmile: Just ordered this one from Banggood -
Never ordered from them before so I’m hoping it’s ok, but people here seem to use them quite a bit. It was relatively cheap and it had free shipping to where I’m at without some of the credit card craziness like Fasttech. It’s still a shame that Paypal won’t let you ship to a different country than where your billing address is located.
Sadly you didnt read clear enough if germ killer is why you purchased. Its been established, with links to discussions off site, that lower than 300nm is ideal for germ killing, while 365 might do something towards it the ideal is in the 260 range. It seems unlikely that the 395 will be much good as a steriliser.
Based on the one AA battery, listed current draw of 350 mA and the inability to use a 14500 battery, based on listed maximum voltage in, this is a quite low power light. This presumes the listed specs are correct, always dangerous with Chinese retailer listings. No idea of what the actual UV output intensity is and whether or not it will meet your requirements.
Nitecore has a much higher power 365nm UV light, the Chameleon CU6, and Eagletac does a UV drop-in for their T20C2 MKII, both discussed earlier in this thread IIRC. Both are 18650 compatible lights from name brand companies.
I was never looking to use it as a germ killer. I just thought it was interesting how this post has turned out from my original one. :bigsmile: I was just looking for a general purpose UV light to light up a few bills and have it to play with. The wealth of knowledge in this flashlight community never ceases to amaze me.
There’s a lot of debate around the wavelength for germ nuking. I’m just going off what my Steripen (battery powered UV water steriliser) emits - 254nm and what Wiki states. Steripen are the leaders for this product and it works great.
And for germ killing, leds are hopeless: wavelength too long, crappy output, very expensive. A cheapy uv CFL-tube is way superior. Leds only come into play if the light needs to be directional, pointed to somewhere away from you.
The only germ-killing I’ve done with a UV light is when I used my 365nm P60 to locate hidden gunk while cleaning. It was very effective for showing me where I really needed to scrub.
Plus, it’s kind of entertaining to show someone what their kitchen or bathroom really looks like. They probably never realized it was so dirty, since they can’t easily see where the yuck has accumulated.
I bought it, hoping to use it as a backup for detecting A/C system leaks at work. Arrived today, whacked it in a spare SF L2 host, & it worked for a few seconds, before failing.
Just pulled it apart now, & it has no driver circuitry - ie; direct drive…. Killed it rather quickly with a Samsung laptop pull…. I guess it was meant to be used with a crappy Ultrafail cell
Bacteria like Clostridium difficile form spores when conditions are not ideal for it. Ironically like when it is exposed to certain cleaning or bactericidal agents like benzethonium chloride. (Household bleach or vinegar don’t trigger this response) Spores protect bacteria from things like the vacuum of space and rubbing alcohol. It’s not the same but in my mind the protective shell is like sunscreen it protects from the UV for a while but you can still get a sun burn. So the UV will kill it but it takes a bit longer. Also there is strength in numbers. Shining UV at a smear or dollop of bacteria will only kill the bacteria on the surface layers. The mess has to be cleaned then hit with the appropriate dose of UV for the appropriate amount of time. There is a fancy robot of sorts that is wheeled into rooms of a hospital like the OR, it maps and measures the room and determines the length of time it needs to bombard the room with massive amounts of UV to sterilize the “Clean” room. Another simple concept that is way more complex in real world use. There is a lot of debate about how effective devices like this are alone as they are advertised. My hospital system is experimenting with one of these towering robots at an undisclosed location. Not the hospital I’m working at as I’m really curious about it.
Oh, oops. I wasn’t talking about that one… I was responding to someone else’s post which appears to be gone now. Maybe it got removed for being spam? It linked to a cheap barely-UV light on eBay and made claims about how great it was for finding urine stains.
Oh, that was you? Huh. I remembered wrong. I was thinking the link was from someone with only one post, and often times when someone links a product in their first post it’s because they’re only here to advertise.
In any case, the ebay listing says several things which can’t be true, and the price is suspiciously low… so I was wondering what kind of emitter was in it.
