Anyone Ever Have A Li-ion Rechargeable Cell Leak?
Sounds like you ran two rechargable batteries when you didn't need to/ or maybe shouldn't have in the first place . ,Most older lights ran on 2 cr123's at 3 volts each and said "don't run rechargables" . any light running multiple batteries becomes much more dangereous since the potential for thermal runaway is present ,running two matched batteries and knowing their internal resistance would be important if domeone insisted upon running two batteries .Most emitters run perfectly well on one 18650 and performance and capacity is usually better . If the bore is the problem you can run a 17650 or a 16650 ..or get the light bored out .
No I didn’t Boaz. I only used one as the light only takes one cell.
I agree with everyone about using quality cells but I’ve had good luck with UF cells in years past but I had purchased them from reputable dealers such as Lighthound.com. I purchased these two cells from Fasttech before I found out, (on BLF by the way), that so much stuff coming out of China nowadays is bogus.
As noted before, I had never had a rechargeable cell of any chemistry ever leak after many years of using them. Yes, I too have had many, many alkaline cells, (from all top brands such as Duracell…etc.), leak and ruin lights and portable electronics and switched to rechargeable cells years ago.
With this experience and others, (like the junk DQG Tiny 18560 II from Wallbuys I reported on in another thread), I’m through with Chinese dealers and will only purchase through reputable U.S. dealers who will replace a faulty item which Wallbuys would not.
Yes, I too succumbed to the lure of cheap prices on Chinese sites but live and learn and no more.
By the way and luckily, after cleaning the goop from the leaking UF cell and restoring the metal contacts back to shiny that had turned black from the leakage, I got the light operational again.
Has anyone ever noticed a Sweet Plastic or Acetone Smell coming from a Li-ion battery?
there was a thread about it a while back, a member who used cells with that smell and someone telling telling them its a bad idea, i don’t remember the name of the thread, but i believe it was texaspyro explaining why its a bad idea, and that the smell is not from the lithium
