Uhhh, ain’t your battery bass ackwards? + is the long bar, - is the short one… at least in Texas
as always gang thanks for the great help/advice for a dumb old novice like myself!!!
Johnny Walker Black drew that schematic. You'll have to ask him. :)
so based on the diagram and my comments, I ignore the led pos and led neg output pads on the KD V2 master and wire as above?
You do not need the LED POS from the master, but you will need the LED neg from the master, IF you want those chips to drive the LED too. That would put 24 chips in the circuit for you (16+8).
16 + 8? My Slave board is 28 Chips by itself - unless its not fully populated?
I just have 16 chips on the board
I got the 16 chip board hooked up to the sst90 aspheric and the a123 - 32157 batt and wow, lots of light! Thanks pilotptk and relic 38!!!
so next newbie question:
power saving - I was going to wire in a KD V2 driver(Thanks again for the info and diagrams) and still may but I am concerned that it may cut out too early when batt voltage drops as the lifep04 battery is 3.4v and the sst90 red runs about 2.0 to 2.2fv.
So - is it possible to just hook up a pwm control to the board? no reverse polarity,low voltage,thermal management,etc.
thoughts /ideas please!
also, still trying to find someone who makes/mounts sst90 onto copper?
You could change the battery cutoff by changing the resistor dividor ratio. I’m mobile and can’t help with a resistor value, but someone will chime in. Just post what you want the cutoff voltage to be.
There are SST90 aluminum sinkPADs, I have samples. You can get some by filling out their survey.
MRsDNF did a DIY one too, and I think someone else did one. Both are posted on here somewhere.
The simplest way to use a NANJG in a lower voltage system is to remove the reverse protection diode and solder across where it use to live. This will give you about 0.6 to 0.7V of extra room before low voltage protection kicks in.
PPtk
PPtk
Is that how big the voltage drop on the stock NANJG driver's diode is!? That might explain a problem I'm having at the moment - I modified a NANJG driver to use a Tiny25 and my own value resistors. I find on high mode (2.8A) my drop-in is halving its output almost straight away (signifying the cell voltage is below 3V) even on almost fresh IMR cells. I might replace the stock diode with the one my code was written for (200mV drop) and see if the problem persists. I did wonder if this was the issue but your post seems to prove it. I was trying not to have to take the driver out for the billionth time!
Yeah, most of the stock ones i've seen are the cheapest, crappiest, silicon diodes you can find. 0.6V or more..
I've run across maybe one in all my years of flashlighting that was a low-drop schottky..
Of course your code could also be screwed up :) (JK Mattaus)
You could change the battery cutoff by changing the resistor dividor ratio. I’m mobile and can’t help with a resistor value, but someone will chime in. Just post what you want the cutoff voltage to be. There are SST90 aluminum sinkPADs, I have samples. You can get some by filling out their survey. MRsDNF did a DIY one too, and I think someone else did one. Both are posted on here somewhere.
I have never seen an SST90. I have done but not completed the light, an MTG-2 direct to copper. I hope the picture can be of some help.
Yeah, most of the stock ones i’ve seen are the cheapest, crappiest, silicon diodes you can find. 0.6V or more…
I’ve run across maybe one in all my years of flashlighting that was a low-drop schottky…
All of mine have Schottky diodes in them… I checked a half dozen or so from different sources.
I should have time on the weekend to re-build a new driver with my own schottky and it's known Vdrop. I'll see if the problem persists then. And yes the code could be wrong, but it's not mine so no skin off my back haha.
- Matt
Well that didn't fix the issue so it must be the code. Then again I should try it on my own hardware as well, not just a modified NANJG driver. Seen as it was written for my own hardware that would be sensible I guess haha.
On a side note I recently rebuilt my PC, got rid of Windows and have switched exclusively to Linux. It seems I backed up EVERYTHING excepts my eagle libraries. Now I have to re-create all my emitter and 7135 footprints from scratch.
That bad, but can't you extract them from the schematics you have made?
http://slopjong.de/2012/12/06/eagle-extract-a-symbol-from-a-project-to-a-library/
Oh that's a great idea! I have done that before but forgot I could do it. Thanks
PilotPTK
I have been away for awhile
do you still have your 28 chip boards available?
and if so, can you populate them with 7135s as needed???
PilotPTK
Might be here
Put your Oshpark driver projects in this thread and I will organize them here in the op. I would like to put all of the relevant Oshpark projects here as it can take some doing to locate them otherwise but will refrain from snatching them without the approval of their creators. Posting a link here will be considered as tacit approval and I will endeavor to keep this op updated. This thread is for the listing of open sourced DIY projects that are listed on Oshpark not for pirating existing work…
