One VERY annoying habit of Eagle when manually routing traces is it’s idea of where you want to do the trace. A lot of times it won’t allow you to start a trace where you want to. It wants the trace to start at the nearest point to an airwire when you do/update the ratsnest display. I often have to rip up an existing trace to get it to allow me to put in the trace where I want it to go.
1 ) Some of your traces route too close to other ‘things’. You must maintain AT LEAST 6 mills (and better 8 or 10) of clearance between a ‘thing’ (via, trace, pad) on one net and a ‘thing’ on another.
2 ) there is no need for the three vias on the trace right next to your connection hole. That’s a thru-hole wire pad, so you can just connect directly to it on the bottom side of the board - you don’t need to via back up to the top side before making the connection. Then you can also eliminate the single via next to the bottom-center SOT-89. Just run that trace directly from the Wire-Hole to the group of four vias in the center on the bottom side.
You’ve still got multiple locations with gaps smaller than 0.006”
Delete the fifth via in this group. It’s physically on top of the two outside ones and will break-out when drilled.
Not critical, but traces like this are really bad practice. It will ‘work’ fine, but its good to get in the habit of not doing stuff like this.
You might want to re-size or re-position the Silk-Screen text. This is what will actually be printed when they clear for solder-mask openings.
You have solder-mask openings around each of your vias. I would remove the solder-mask opening from top and bottom side. The copper in these areas will be exposed if you leave these mask openings here.
