Anyone know of a charger (4-bay ideally) that fits 26800's?
26800 is not officially supported. It just happens to fit. I have to insert mine straight as well. I don’t think 26800’s we’re popular and may not have existed when UI2 was designed.
I did not mean for Nitecore to include 26800 in the UI2 description but 26700 since the 26800 fits perfectly as seen in your video.
I’m stating Nitecore may have meant to put 26700 in the U12 description and not the UM2. Candlepower has an announcement showing Mar 14, 2019 for U12. Amazon list first date UM2 appeared on Amazon as March 10, 2019.
It’s a shame Nitecore didn’t increase the UM2 length slightly to accommodate 26800 since Nitecore’s description has 26700.
Your video shows the 26800 fitting better than the UM2 I have. It seems to slide right in. I have to angle it perfectly than use a little bit of force. If I make it fit completely flat, it is a pain to get out. I prefer to have the cell slant downward with the top at a higher angle than the bottom when charging.
I don’t think there’s any reason to believe it was a mistake. Both chargers support 21700 cells and both support 26650 cells, so both will definitely support a 26700. It’s just an odd size that nobody really cares about so it was likely just left out of the one product description. For instance, the UI2 lists support for 14430 cells, while the UM2 does not, but I am sure it would work just fine. The UI2 just happens to have a slightly longer bay so it works with 26800s. It may be putting more strain on the springs than intended and may shorten the life of the charger, but they’re cheap enough and there aren’t many other options.
This is only logical. You don’t want the electrons to spill out the top.
I should have known it was a member here :slight_smile:
Good review.
I have the Olight charger with the magnets and it`s taking forever to charge my cells.
I`ll be getting the Nitecore charger in a few days. I would think it would be faster than the Olight charger.
Can’t tell if you’re being serious but practically making it completely flat makes it too hard to get out and can easily damage the wrap. I just wish Nitecore extended the bay by 100mm. I’m wondering how good QA and if maybe there’s UM2’s floating out there which can easily fit 26800.
Has anybody done a test and measured how fast the Olight charges 26800? It probably maxes out at 850mah
UMS series can charger faster but looks like hit or miss on fitting the 26800 without modifications.
https://www.reddit.com/r/flashlight/comments/sdnl92/nitecore_ums4_works_for_26800_batteries_but_a/
Perhaps not in your lexicon, but that would be 10mm and “QC”.
Don’t want to downplay, the info is very helpful as I’ll be looking for a 26800 charger.
Personally I’d pass on this for 26800 cells simply because there is so little room….tearing wrappers aside, if something ever goes south and you want or need to remove the cell(s) quickly, it’d be nice to have some more room to pluck them out easily. It’d be good to be sure the charger can handle the extended charge time and associated heat that comes with these higher capacity cells, too, since they’re crammed in there.
I don’t think Nitecore cares about 26800…they make their chargers with their own products in mind. The fact that it happens to fit is just a byproduct of them needing to be able to fit their long protected 21700 cells in there (I assume).
We haven’t been doing 26800 in lights now for even one year yet, so it’s surely never been on anyone’s radar for chargers, other than the hobbyist type chargers (and diy of course).
Wondering if Xtar was really serious about introducing one, if they dropped the idea, or if they’re perhaps impacted by the chip & component shortage like so many others.
https://www.reddit.com/r/flashlight/comments/tdxgsr/new_26800_charger_from_xtar_to_be_released_soon/
Probably whenever Covid gets better in China so maybe in the next 4 months?
I was asked to review the 26800 charger, so it is happening.
(I turned down the offer though as I don’t have any 26800, and don’t intend to).
Thanks guys, that’s good news! Kinda was hoping for a full on 4-bay charger with all the goodies but I’d settle for a single-bay for now.
I’ve recently also tried the Nitecore UI2, and the slot is very slightly longer than the one on the UMS4.
Whereas on the 4-bay UMS4, some of my 26800 (I’ve got about 3-4 different kinds) barely fits, some 26800 batteries (just a tad longer), don’t fit in the Nitecore UMS4.
Whereas on the Nitecore UI2, all the different 26800 I got fits (still quite tight, but fits and shouldn’t tear the wrapping, unlike when trying to force some 26800 batteries in the UMS4.)
