I firstly clean all new torch threads with Turps. Wipe with old tooth brush.
Then.
I have a tube of INOX mx6. PTFE Machinery grease.
High temp, E.P. Food grade.
Thick. NOT really greasy. Lasts forever on twisty’s.
Says.
Anywhere a HIGH TEM’P. NO MELT. Extreme pressure
grease required.
It doesn’t run out of any of my high output torches.
My first purchases with Bangood were yrs ago.
Apart from one doa, one with sw that went walkabout later. Died.
and 2 x wrong size rear metal switches. ALL fixed.
I’ve always got what was ordered.
And had civility from the person I speak to.
Oh. It took a long time to get a S2 torch I won a long time ago.
Thought they forgot.But sent another by return email.
That first silver one never fronted.
I prefer the BLF A6 over the FW3A. The A6 just seems a lot tougher and more reliable.
About a month ago I was using a BLF A6 as a rear light on my bike (with some red gel filters). It dropped off without me noticing. I thought I lost it, but a couple of hours later on my return trip I saw it up ahead, flashing away. No damage, just a very small ding on the bezel. It hit the pavement going about 25 km/h, and luckily never even shut off (or there’s no way I would have found it in the dark).
I think if my FW3A did that, it would have smashed into a dozen pieces and the tailcap exploded.
In addition to my BLF A6 lights I have two Astrolux S1, in red and blue. With the 18650 battery tubes fitted I have two more A6s. But I usually use the 18350 tubes just for the variety. It's good to have options.
due to green tint in my A6, i switched to Convoy S2+ 4500K added FET driver with Bistro UI
and it has smooth tail, unlike sharp tail on A6
minus be the clip, clip is much better on A6 but Convoy clip have never failed on me yet … just doesn’t feel as firm
I’ve got a silver A6 and a red & blue S1 (w/ 18650 tubes for each). They are wonderful, solid lights for those times when having light is more important than bells & whistles. For the price, I don’t think you can do any better. OK, maybe the Convoy S2 line, but I don’t own any of those (yet), so I can’t speak to their quality.
I just got an FW3a too. It’s nice. I rather like the ramping compared to the fixed levels of the other lights. It’ even compatible with ‘normal’ folks when Muggle Mode is enabled. It’s a bit more expensive, and I think I need to open it up and do the general cleanup to remove grease/oil from contact surfaces… but overall I’m quite tickled by it.
On paper, the ZebraLight SC700Fd 21700 XHP70.2 Floody Neutral White High CRI Flashlight looks like one of the better hand held flashlights, these days. If I could afford its $119 price tag, I would buy it over the BLF A6. Then I would buy two or three A6s to go with it!
'Course, I already have three. They were very affordable, indeed.
One thing I have decided is that I strongly prefer boost and buck-boost drivers over FET and similar "direct-drive-like" drivers. I don't like it when output slowly declines at the battery goes down.
If I can get it, I also really like high CRI.
The A6, which offers neither of these, certainly ain't perfect, but, hey!, what flashlight is? I use my A6s almost every day. They're great.
Yeah, Zebralights are far better lights than the BLF A6, but they’re also much more expensive. Worth it, IMO, but perhaps not worth it to everyone.
For a comparable light to the A6, I’d go with a SC600w MkIV HI (throwy-ish) or a SC600w MkIV Plus (floody). Or just the regular 600w for an in-between beam profile, though I prefer the SC64w HI for that.
But it’s tough to go wrong with the BLF A6, when you can buy 4 or 5 of them for the price of a Zebralight.
