tallboybass, shhh, donāt tell anybodyā¦.I actually do this stuff with a nerve disorder. Shhhhhh. I donāt want anyone to know. That Iām a stubborn persistent opinionated old grump. Well, getting old. lol
Kidding aside, in all seriousness if I can do this, most anyone can do this. Just takes patience and determination. I do have a nerve disorder, but it attacks me at times, not always affected by it. Itās just ironic that sometimes I have no control of my body, and otherās Iām soldering resistors the size of pin heads. Like Scott says, a good iron is essential. I got a Hakko 888 station and it opened up a new world to me. Pretty much use one tip. I got a second one, itās the same as the first by mistake, so I filed the end down for a narrow screwdriver looking tip, use that for the chip legs. Get lazy and donāt take it off. I also have too much time, so I am free (mostly) to dedicate hours to doing a light or a single heat sink. Much to the chagrin of my wife. But she leaves it alone as thatās hours Iām not buggin her! When in the so-called āhuman latheā mode, I donāt like to stop for a new li-ion battery for the cordless drill, or to go to the restroom for that matter. Stopping to eat is a huge pain! I an spend 4-5 hours hunched over a copper rod making a heat sink/pill. No sense of time, or no sense, take your pick.
A 7/8ā diameter by 3ā long bar of copper, with a .45 Long Colt brass JB Welded to the end and partially filled with JB Weld to mount in my cordless drill. My ālatheā, I cut it with the dremel tool. Sitting at a glass patio table on the back porch, left elbow holding down the drill, right hand holding the dremel, left hand stabilizing the right hand. Thatās it. Hoursā¦
Iāve made two of those, and another in aluminum, a 4th in smaller scale in aluminum for the chopped AA mini mag Triple and a 5th in even smaller scale for a 10440 sized mini C8, also in aluminum. The aluminum ones I cut down from a 1ā bar of 6061. I also made a Nylatron GS insert for an old Brinkmann Legend LX to put a laser module in.
The Nylatron GS turned out to be much tougher than I expected, had I known how strong it is I probably would have made the above from aluminum. That bar is 32mm in diameter. Took a while. lol
Like quitting smoking, you make a decision then set about making things happen. When youāve made up your mind to do it, you do. Whatever it takes.
When I was a kid, my Dad owned a Lumber Yard. Our little side building that held Cement and Mortar had a 3-0 door on it, a pallet wouldnāt fit in. So every time we got a truckload of Cement/Mortar (400 bags of Cement, 600 bags of Mortar) every bag had to be hand carried and stacked in that little building. Every order that went out, had to be hand carried out to a pallet and hand unloaded off the truck at the job site. Cement is 94 lbs, Mortar is 69. It is what it is. You might not like it, but itās got to be done. So you have at it! I was stubborn even then. At 135 lbs, (most of my life) I could curl 50lbs with each hand and carry sheetrock, shingles, cement, whatever, all day every day. When faced with carrying 60 bags of mortar at 69 lbs a bag, Iād carry 2 at a time to get it over with.
Thatās the mindset I use to do some of these mods. I donāt have proper equipment. So by carefully using what I DO have, I make do.
