Armytek tiara A1 Pro XM-L2
My Wizard Pro wide has been a good headlamp. I would buy another light from Armytek. The only reason I don’t carry it at work is because I also own a Spark headlamp that is in neutral white tint which I prefer. I wish I got the Wizard in NW but I was dazzled by the CW lumen numbers.
Hi Slim. I have the same light as you. Thanks, I guess, for all your work, graphs, charting, etc. I put an Eneloop in my light, or a 14500, and I turn it on. When the cell gets weak I take it out and charge it up. That’s my methodology. I am clueless as to what your graphs are saying. Just asking you, as an owner of a Tiara A1 Pro WW, are the charts good news, or bad news, for me?
thanks…
patrick
Patrick,
Here’s the graph I really should have posted initially before I got a bit carried away :beer:
These runtime plots illustrate that the Tiara A1’s highest mode has quite flat output (good regulation) using regular 1.2V rechargeables such as Eneloops. I’m really impressed at how the Tiara gives consistent brightness even when the battery is nearly flat. Importantly (and the graphs don’t capture this very well) I noticed that when the output drops out of regulation on Max, it still has sufficient juice to power lower levels and you aren’t left in the dark.
I have no 3.7V 14500s yet, but I plan to get some for EDC’ing this light in the future. I occasionally carry a neutral Wizard Pro so it’ll be nice to replace it with something a little bit smaller.
Edit: I fixed the link to the new, cleaner graph image (I tried publishing it directly from Google Drive before but I guess I didn’t do it correctly, oh well).
thanks Slim for explaining things that me, and possibly some others, might not understand from those technical drawings :slight_smile: Sounds like good news! I’m really happy with this light. Beautiful beam, built very solidly, and my switch has loosened up a bit thankfully. No need for me to get a ‘first’ Zebralight now.
note: I’m not able to view this graph here, others probably are?
thanks Slim!
patrick
Just to update my post. Double click from high takes you to back to previous main mode (memory mode) then single click off. So yes, it can preserve previous mode memory after using high.
I know that this is a somewhat old thread. But I figure that now that I have a Tiara A1, I should answer this question. The simple answer is that it DOESN’T produce 550 lumens (or 515 lumens for the neutral). At least not out the front. Then again, Armytek is quite forthcoming in saying that the output is given in emitter lumens. I don’t have an integrating sphere to measure output. But comparing it to other lights I have, I estimate the output to be around 350 lumens out the front - certainly not bad. And probably not too far off from the given spec of 515 emitter lumens.
Speaking if lights to compare it to, it’s quite a bit brighter than my SC52w. I’m sure it’s also brighter than Zebralight’s H52 series (which is based on the SC52, and is about as bright). This means that the Tiara is the new king of brightness when it comes to 1xAA lights, even though you almost never even hear about it.
Advertising money goes a long way on “some” forums.
Sorry to necro this thread, but I’m interested in the Tiara A1s and I keep seeing the Pro version and one not labeled Pro. Can anyone enlighten me on the difference?
Thanks
should be able to read about the differences on this page. Armytek didn’t even have the two models on their site that I could see.
Pro version has 2 additional blinky modes
Thank you.
sorry, forgot to enclose the link: u can read about the differences here.
http://www.illumn.com/flashlights/armytek.html?\_store=default
Also has 2 Very Low modes (versus 1 for the Non Pro)....
The Tiara A1 Pro output levels & runtimes are: 550 lm (30min), 250 lm (1h 10min), 85 lm (3h), 12 lm (25h), 2 lm (200h), 0.1 lm (90d), 2 Strobes
The Tiara A1 output levels & runtimes are: 550 lm (30min), 250 lm (1h 10min), 85 lm (3h), 12 lm (25h), 2 lm (200h)
Best Regards,
George
Just to sum up.
2 blinking modes
1 additional ultra low mode
A magnet in the tailcap
I did a review of the Pro a while back.
Ooopsssss, I forgot the Pro also has Battery voltage indication...
Regards,
George
Which, at least on my light, doesn’t give the correct reading very often.
it seems to work better in checking the battery on a 14500 cell rather than a AA. Also, don’t forget to set the light for the correct battery when 1st installing one (I don’t really know if that matters?)
I have the A1 Pro, warm tint and I am VERY HAPPY with this light, running it on a 14500.
Yes I did all this. It worked right maybe 1 out of every five tries. I found it worked no better when using a AA or 14500 in my testing.
