Astrolux/Bangood strike again! MF01X Fail - Customer Service Fail.
Top tier kek.
I’ll refrain from buying anything flashlight related from Banggood.
A 7 day DOA warranty period is pathetic. Even past 7 days, if the light doesn’t work, then they should try to get you up to speed still.
@ Thermolumo:
I had never seen such 7-day policy. Talk about a hidden agenda! And they couldn’t sway some; you were out of town. In doing so, they lose: either forfeit the cost or the customer.
Hopefully, you had the dispute resolved with PayPal. So they lose both ways. Not very intelligent.
On my end, the first time my Astrolux FT03S had an issue, some 20+ days after receiving the light, they offered a free driver replacement. I had asked them to take it up with Mateminco to have a corrected version. They didn’t respond. It took some 60 days before I took the dive and re-confirmed the replacement. And sure enough, it came within 20 days of shipping.
Well, that 1st replacement has the same issue – never turning OFF; always very dim. Mind you, this after some use since June ’20. I had reached out to Mateminco for a new driver (never mentioned this recurring problem), but all too quickly slapped a $20 fee and $12 shipping (all USD = $56 CAD). Trying to get them to ease up some, I nudged this was a replacement but they quickly snapped “you didn’t purchase from us.”
BangGood did offer a replacement at a reasonable cost of $13 CAD. Had an issue with accountability and tracking, but nonetheless, the driver did make it to my mailbox.
I’m not too keen on replacing again (2nd time). I’m trying to figure out why the driver stays in very dim mode. This 2nd driver behalves as such when hot. After a long cooldown, it returns to its proper OFF state.
Edit: Might try some thermal putty between the MCU and the USB hub.
Regarding the better merchants, their presence here on the forum confirms some degree of follow-up and accountability.
Even FastTech is doing some PR to re-establish their credibility. They had trashed a few people and it left scars.
Kaidomain has some delayed processing issues and any newbie may worry some, especially when they don’t respond to messages. But they always delivered my goods, never any faulty items so I might not know of their return/refund policies.
Unfortunate that BG is taking the cheap “screw-them & move on” approach. Not offering any work-around for a pricey light is bound to have negative feedback from their market.
Afterthought:
This be my conjecture, but the business exchange between BangGood and Matemico may not be too ‘camaraderie’. Mateminco has produced some good lights and their deficiencies do get posted here. FreeMe did make a thread regarding these first issue lights and some bugs will be inevitable. As an OEM they would have the responsibility for returns of defects, but time constraint to make these new designs leads to design faults. That hurts the bottom line and naturally, they would push some of these to BG as DOA would be a shipping issue. To cut their losses, BG would deny replacement/refund.
In short, the consumer is not well served. Saving some money on pre-order group buys may not be worth the risk.
Have you tested if it’s faulty 7135?
@ Haukkeli:
Now that could be the culprit. Being a double board, I’d have to remove the USB and might as well change all 7 AMCs.
How to test them for leakage? Might not be worth the trouble. Have plenty in stock.
I would think that if one leaks then when switched off the current should be 350mA or 380mA, when measured from tailcap. Which one leaks is another story. I don’t know is there any method other than thermal camera. The one that warm up,leaks.Without thermal camera I would start by removing the one that’s responsible for the lowest modes.
I would have to guess as to which is for the “moonlight” mode – perhaps either one from the MCU sides. But for all the trouble of troubleshooting and checking on the bench with all the wiring, perhaps changing the lot is easier.
But I’m going to test a copper pill sandwiched between the FET and the USB hub. There are thermal issues also.
The 2nd driver had a beefed-up de-bouncing cap across the switch. Would these also leak?
I don’t know. Everything is possible.
As for that de-bouncing cap, I’ve had some that went into trickle mode. Don’t know if the engineering of the making or the solder / flux that gets underneath.
Your take?
Ah, you meant cap as a capacitor. I thought cap as in tailcap and started to wonder all kinds of constructions. If it leaks DMM in conductivity mode should tell?
I’ll have to take it out, my line DMM for such isn’t giving any accurate readings. One of these UNI-T UT116C SMD Tester
Ok. Mine is Aneng AA8008 if I remember right.
That UT-116C DMM is specifically for SMD on-board measuring. Don’t know how they work, usually give the readings across the component and not the circuit. But just doesn’t register that cap. Maybe it’s conductive? I’ll have to check when I’m back in there. Yep, conductive at 120 kΩ.
Took my evening walk with the FT03S and ran it for a good 12 to 15 minutes on high. No more dim hang-up on OFF. That copper pill between the FET and USB seems to have fixed the problem. Not too hot as I have it ~4000 lumens ceiling. Later will be testing further.
I’d like to thank Haukkeli for the valuable insights and diagnostics. I lack the experience but with a helping hand, it’s much more encouraging.
Now back to our scheduled program (derailed thread)…
Hello Sir,
Sorry for the inconvenience, can you PM your order number and more details about the questiion to me? I'll check what happened. Thank you for your help.
