Did you remove the bleeder resistor?
And I don’t know if we can trust clamp readings at this little currrents.
Not that I’m aware of … Thanks, I guess I kinda missed that… How do I recognize the bleeder resistor?
It also sporadically jumps modes now, for example from moon to a high mode…
At the banggood X6 driver it goes from the LED+ pad to ground, labelled 471 which means 470 Ohms.
How many amps does your mod pull at turbo?
Thanks for the info TK & Flashymike! Does removing this resistor remove any functionality? Like mode memory or something? Sorry for the noob question
Just did a quick tailcap check, on a full 30Q it pulls just short of 13Amp.
It is only needed for a lighted tail cap on lights with tail cap clickies - which you don’t have, I assume.
With that high currents I wouldn’t recommend the Banggood X6 driver. At currents above 9 Amps it tends to reset the mcu due to inductive spikes. I’ve read the Mountain Electronics drivers are better.
Yea, for 17's, I'm using the MtnE drivers exclusively now - got all the parts in, including the 0402 resistor - talk bout small... On the MtnE boards, I use 191K resistors for R1 because the resistors are after the diode, not before, opposite of wight's drivers.
Dutcheee - I hpoe you don't mean in that order as you said: I just flashed the new Narsil with ramp and replaced R1 & R2 with 47K & 220K resistors
R1 should be the 220K, and R2 the 47K. I haven't used the bleed resistor in any of my driver builds, 85 or otherwise.
Here's a pic of a working MtnE driver, the MTN17DDm, v1.1:
This evening, I'll double-check battery level checks on these MtnE boards. Every 85/Narsil I've built with the new ramping support battery check and LVP work fine - I've tested I'd say about 6 working lights so far w/latest Narsil, 3 of which are in SRK style lights, doing 15A to 20A each (3X modded M6, 4X clone, 5X clone).
Last night I just updated my SWM C20C with the ramping version. It blinks out 3.9v and with the cell removed, it measures 4.007v on a Fluke DMM. I consider that close enough, but the driver is a wight driver, so I'm using the 220K/221K resistor for R1.
Important Note: To properly measure parasitic drain, you must hold the probes across the batt- to the housing for several seconds, I think it's about 6-8 seconds. I added this delay to the firmware intentionally - it's a delay before going into sleep mode. I just did this on my C20C light, and measured 0.02 mA, whichs is 0.016 mA rounded to 2 decimal digits. Looks like this Fluke I'm using at work (175 - true RMS DMM) is limited to 2 decimal digits.
I measured 4.85 mA for those first few secs before it drops. The 4.85 mA is probably the MCU's draw in normal running.
Thanks for all the quick replies :+1:
I believe so, but I’ve used this driver at high temp. and 13A with the AT85 mcu for quite a while now without problems.
I’ll remove the bleeder and see if this fixes anything.
It only jumps from moon to some high, not being turbo.
From low and higher settings (just above moon and up) I haven’t seen it “jumping” yet.
At the high amps, all works well. I’ve set the turbo stepdowm to 15secs and it does so every time.
If removing the bleeder resistor doesn’t fix it, I’ll replace the original resistors and see if that fixes it. Parasitic drain isn’t that much of an issue, because I tend to lock it out anyway.
And then I’ll order some boards from MTN, hoping to get things right in the long run…
Yes, offcourse. I replaced them 1 by one with a factor 10 bigger. That was a typo.
Oops, more details added to post #949 above.
I don’t know about the ATtiny85 but the standard Banggood BLF X6 driver has a ATtiny25 mounted. This mcu has problems with high Amps, the ATtiny13a on the same PCB doesn’t. Interesting to hear the ATtiny85 does not show this problem, perhaps I will give it a try. Have you used your high drain cell with this mcu earlier or did you use lower drain cells?
Is it possible to mount the ATtiny85 with a soldering iron in the place of a ATTiny13a or ATtiny25 or do I have to reflow it?
I use hot air reflow, but it's possible to hand solder I suppose - just need to do a good enough job wo you can still clip on to the MCU and re-program, You have to bend the pins of course - can be a challenge - just a warning. With the bent pins, it's actually easier to program in place.
I for one would not use the BLF X6 driver - don't trust the quality. 25/45/85's have all the same problems with our standard circuit design. My fixes include:
- pull down resistor on the FET gate, from 12K to 20K, high ar 47K or so
- for C1, double up the 10 uF cap (add one stacked) -- BLF A6 uses a 12 uF cap, not 10 uF!! Pull it and test it if you don't believe me, or, maybe they are sneak'n in 10's now, and that's why it's flaky
- add a 0.1 uF cap across pins 4 and 8 (grnd to VCC)
The combo of all 3 of these always works, every time, for me. Sometimes you can get away with just the FET gate pulldown, sometimes FET gate pulldown and the 0.1 uF cap. This is why Richard has all these extra parts on his driver (zener and schottky, FET gate pulldown, etc.), and why our BLF Q8 Narsil driver board has all the extra stuff as well, but we have a slightly different approach.
Thanks Tom E, I don’t think I was patient enough to sit the 8secs out… Will test again.
It’s weird, because now it looks erratic at high levels as well. I’ll remove the driver and see whats wrong when I have the time.
Flashy Mike, you can see how I did it here: DQG tiny 4 mod
It worked flawless on 30Q’s and lower drains. Stock X6 driver with only AT25 replaced by AT85 running Narsil without ramping.
Edit: Thanks for the mod list Tom E. I don’t really understand why this FW doens’t work now on the same driver. Just swapped 2 resistors… Guess I got lucky to begin with.
I’ll need some more parts then…
I thought this was the final mod on my DQG. Now I know there are many more to come… I quite like that idea :partying_face:
@Tom E:
Thanks!
@Dutchee:
Interesting mod!
I saw the bleeder resistor in place on your driver there. If you don’t remove it you can’t reduce parasitic drain below about 9 milliamperes in your e-switch light.
Got a new version of Narsil posted, several bug fixes, minor enhancements and tweaks:
Direct link to the ZIP file for Narsil 2016-07-11.zip
or link to the complete folder, where you will find the above ZIP file and the manual in two forms: docx and PDF.
IMPORTANT NOTES:
- be sure to grab the 2016-07-11 version, while the manual is still dated 2016-06-08
- In the ZIP you will find a notes.txt that has the list of updates - current version is 1.11
- Narsil is only configured for FET+1 drivers, using a 350 mA 7135. Of course battery voltage is dependent on the driver design and parts used
- Narsil requires an ATtiny85, and a ATtiny85, along with 25's and 45's, can be finicky, and best to have some mods made to drivers designed for 13A's. So far, the most reliable drivers to use are Richard's MtnE MTN17DDm v1.1 which is designed to run a 25, but seems to run an 85 just as reliable. Also our newly posted and moderately (lightly) tested BLF Q8 SRK driver.
Here's a full parts list for the BLF Q8 V3 SRK driver:
- OSHPark Driver PCB for BLF Q8 V3: https://oshpark.com/shared_projects/QQxa6req
- ATTiny85 20SU (http://www.mtnelectronics.com/index.php?route=product/product&path=25_104&product_id=601)
- SIR800DP FET (http://www.mtnelectronics.com/index.php?route=product/product&path=25_76&product_id=565)
- 7135 - 350 mA (https://www.fasttech.com/products/0/10001705/1124300-amc7135-350ma-advanced-current-regulators-sot-89)
- D1 - Schotky diode (our standard OSHPark D1: http://www.mouser.com/Search/ProductDetail.aspx?R=ZLLS410TAvirtualkey52230000virtualkey522-ZLLS410TA)
- C1 - 10 uF 16V 0805 X6S (http://www.mtnelectronics.com/index.php?route=product/product&path=25_104&product_id=440 or http://www.mouser.com/Search/ProductDetail.aspx?R=GRM21BC81C106KE15Lvirtualkey64800000virtualkey81-GRM21BC81C106KE5L)
- C2 - 0.1 uF (I believe 16V, good quality)
- R1 - 220K 0.5% (http://www.mouser.com/Search/ProductDetail.aspx?R=RR1220P-224-Dvirtualkey67280000virtualkey754-RR1220P-224D)
- R2 - 47K 1% (http://www.mouser.com/Search/ProductDetail.aspx?R=ERJ-6ENF4702Vvirtualkey66720000virtualkey667-ERJ-6ENF4702V)
- R3 - 47K 1% (http://www.mouser.com/Search/ProductDetail.aspx?R=ERJ-6ENF4702Vvirtualkey66720000virtualkey667-ERJ-6ENF4702V)
- R4 - 100 ohm (specs unknown - from FastTech)
Note: R5 and ZNR are unpopulated
If you choose to use this, Best to let me know what you are planning on doing. I can answer any Q's you have. This thread has a lot of the history on the 25/45/85's here, all the pain and suffering as well...
Here's the content of the NOTES.TXT file, listing all changes in this version from prior 2016-06-08:
Open Issues:
1: Bug: strange behavior on power fluctuations on power-up (lockup w/LED ON intermittently occurs)
2: Potential Bug: in mode sets, can't get battery check to work (might be from corrupt config settings)
3: posssibly easier/quicker way to toggle between ramping and mode sets
4: utilize 4X and possibly 5X clicks
5: possibly remove memory mode for mode sets
6: add version # reporting - blink out the vers #
UPDATES
Vers 1.11 2016-07-11:
- bug fix: dbl-click or triple-click in Battery Check mode were being acted on (should be ignored)
- in ramping, add a timeout (1.2 secs), after which, to not toggle/change the ramping direction
- bug fix: with turbo-timeout enabled and in ramping with moon mode active,
the turbo-timeout kicks in and turns up the output to turbo drop down level -- fixed this
- slightly speed up multiple click timing (shorten LOCK_OUT_TICKS from 16 to 14)
- in ramping, if you turn the light from OFF to ON to the previous level, the direction will now
default to lo->hi
- add changes in an attempt to eliminate power fluctuations causing a lockup or coming on with the
LED ON (lockup still happens, but doesn't seem to come up with the LED on and light still
operational anymore)
Vers 1.10 2016-07-06:
- add validation marker byte (0x5d) to avoid loading erroneous config settings - seems to work in
fixing the observed behavior (still open issue on lockup)
- add flicker when ramping reaches the limits
- bug fixes: if holding the button for entering battery check, don't allow config setting or strobe
modes to be started
- bug fix: in ramping, when click to last level and last level is moon, the ind. LED was left ON -- fixed this
- add a compile switch to enable reverse ramping direction (toggling)
What progress!
Bug 1 reads like a nasty bugger ( ) does any other Narsil user encountered it?
Oh man I am so going to dive in this coding thing this winter, want to learn coding anyway.
Seems like you’ve been busy!
Is that power-up as in turning on the LED? Or as in inserting batteries? I’ll try giving it a read as sometimes a fresh pair of eyes helps.
Inserting batteries - meaning powering up the electronics. I've only seen it somewhat rarely when I'm fiddling with a stubborn threaded tailcap and the threads aren't anodized. I can reproduce it, after fiddling around for a while, intentionally trying to cause it.
Dunno the cause yet, or what I can do to fix it - hoping for some help on it. Maybe someone stumbled across it before? Being that the side switch doesn't seem to work at all when this occurs, can't figure what might be happening - almost like the MCU is in a funky reset state, or power-glitch state.
Have you tried enabling the brown out detector? The comments suggest not by default. You could have low power without a proper reset if power is cut for a very short time (likely far less then 1 ms). Then I suppose anything could happen.
(Edited to remove nonsense theory as the LED is on.)
Hhmm, didn' try that. Think someone said though brownout detection enabling is a killer for e-switch parasitic drain?
Since the MCU locks up, you're probably voltage spiking the MCU when the tailcap is getting fiddled around. When connections are intermittent and arc/spark you can generate some pretty big voltage spikes. I'll bet if you hook up your fancy oscilloscope at work to the VIN pin and and ground pin then play around with the tailcap with the trigger set at 6V+ you'll see a pretty nasty voltage spike.
Still no temperature sensor support? Even external?
