now we are getting to the good stuff, can we mix diffrent mah rated batteries.
there is two lines of thought here, one is its only the end voltage that matters and the other line of thought is no dont mix cells, or you will explode and go to hell.
am little example when parrallel ballance charging lipo battery packs that are made up in series (say all 2s 7.4v 2s1p) with a parrallel ballance board you can mix mah rated batteries (say 1750 mah & 2200 mah ) as the charger will only see the end voltage of 4.2v per cell, so as long as they all have the same end voltage its fine.
now since we are making li-ion series packs i think you should be able to do the same, mix mah rating as when the battery is full it will read 4.2v or close to, i tryed to use all the same brand but when you test the batteries seperatly they all have slightly diffrent internal resistance and mah rating so its kind of same same or yes but no, if that makes sence, and i have mixed brands and mah ratings with the balance set ups ive made sofar.
i have not tryed to mix diffrent batteries like 18650,s and 18350,s as i only use 18650,s this far, but it all should be ok as long as they have the same end voltage, i have and will charge diffrent mah rated batteries together as long as they are the same cell count and same end voltage, another reason why i think balance charging is safer.
with series charging the gap in the voltage is not a big deal there can be more then 1 volt no problem, it just might take a little longer to ballance charge, but when balance charging group,s your saving alot of time so its all good but with parrallel charging i would not atempt this though.
i my honest opinion there is no pointbreaking in or cycling li-ions or lipo,s, they will improve after a few charges but thats it, they dont need to be cycled and the best way to cycle them is charge them when you first get them and then to use them and then charge them and keep going, i belive cycling batteries was and is only needed for nicad,s as they do have momory the lithium based batteries dont need to be cycled or broken in so to speak as theya re diffeent chemistry and no memory.
and yes hyperion make realy good chargers ! ive used a couple but have not owned one as im a tight arse, i do like the ichargers they are middle range, not the best but much better then most, but people will always go for the 25 dollar charger and i can not even talk people into spending 80 to 100 dollars on charger,
