There must be some other item in your cart with unbeatable price - it doesn’t have any special designation beside usual orange Promo tag.
Purchase this item in separate order. You can use check marks on the left side of the item to disable it from current order to see which one is causing the problem.
If that’s not the case or you only have one item in your cart try refreshing your cart and/or clearing browser cache and cookies.
XANES 300LM Sensing Headlight Night Fishing Cycling Double Light Source Rechargeable Clip Cap Lamp is in preorder for $5.99. ~150 pcs left at that price. Main LED with reflector seems to be Cree XP-E, there’s also COB LED for diffused light. Package includes headband (not pictured) and apparently 2 USB cables.
IR sensor probably works similar to Boruit IR “sensor” headlamp - i.e. just for switching selected LED on and off. Description does not clarify that aspect.
Battery has standard 2 pin connector (same as used in small drones) and is easily replaceable.
BlitzWolf® BW-LT5 Pro IP68 Waterproof LED Panasonic 3350mAh Powerbank Emergency Camping Lantern with coupon travel is 20% off at $15.19.
Lamp uses single 18650 Panasonic NCR18650B 3400mAh (typical, 3350mAh minimum) cell but it’s not replaceable, it’s USB rechargeable and has ability to charge other devices via standard USB type A female port. It is completely waterproof, white light has two steady modes with up to 75h runtime in low mode + 3 modes red light (2 emergency blinkers + steady red), uses separate blue LED as charge indicator.
Astrolux S1 XPL 1600LM 7/4modes LED Flashlight 18650/18350 use coupon 76648A or 2017FNL to drop price from $29.95 to $20.96.
This is exactly the same flashlight as BLF A6 but with different name and additional matching 18350 tube already included in the box.
Haikelite is under restocking right now so we have to wait until new stock arrives. When the light is avaiable again you can use BG points to drop price according to your account VIP level as shown in the table. You still need enough BG points to do so.
BlitzWolf® 15W 2A Foldable Portable Dual USB SunPower Solar Cell Panel Charger with Power3S using coupon code D321CD brings price down from $32.99 to $26.39 (20% or $6.60 less). This panel can easily charge any smartphone and will also charge in overcast conditions as well (with decreased rate of course).
Registered shipping included but currently in preorder - stock is due to arrive on May 31.
The flashlight uses 2xAAA cells and Nichia 219B LED with CRI over 90 at CCT=5000K. It has 3 modes and always starts in low (4lm), medium is at 45lm and high at 180lm.
