SP31 looks like an amazing deal! These days u can really get a good flashlight at a cheap price.
I have 3 more SP31s on order and received my first yesterday. I like the size and weight very much. Its barely larger in diameter than an 18650 battery. Output is pretty decent for a light of this size. It’s not near as bright as the Zanflare F1 , atrolux s1 or the convoy S3 but I estimate around 900 lumens which is good for the size. It is smaller and lighter than all three of those lights.
The dual switches are nice.
I wish the tint was a little cooler but I like cooler light than most here. I estimate it’s around 5000k.
Bottom line, for around $10, its a very good buy. Compared to $12 (coupon) for a Zanflare though, I will take the Zanflare.
Astrolux K1 XP-G3+365nm UV+Red LED 350LM New Driver USB Stainless Steel Mini LED Keychain
Version with XP-G3 is now in preorder for $18.95 ($32.95) until Dec 19th.
Coupon code 1abad6 for selected Nitecore, Klarus, Imalent JetBeam and Lumintop flashlights:
LED Flashlights Christmas Celebration 30% OFF
collection.
BlitzWolf® BW-T1 XP-G3 S4 750Lumens Portable Tactical LED Flashlight 18650
Newest release from Blitzwolf. Simple no-nonense 18650 EDC flashlight. It’s now in preorder for $10.99 ($19.99)
Offer expires on December 25th.
- Cree XP-G3 S4 2A tint (~5000K)
- 4 modes: high 750lm (3.5h), medium 250lm (5.7h), low 70lm (19.9h), strobe
- 147m (160yd) range
HaikeLite MT03 II Devourer XHP70.2 2SPS New Driver 12000LM High Power LED Flashlight
Use coupon code 90656f to lower the price from $119 to $95.
- 3x Cree XHP70.2
- max 12000 lm
- N4 Cool white or N2 Neutral white tint options
- black or silver/white finish options
- 10 lm lowest setting
- LED power indicator (lighted switch)
- copper DTP emitter board
- Ultra Clear double side AR coated glass lens
Jetbeam TH15 XHP E2 1450Lumens Ultra-High Performance Tactical Outdoor LED Flashlight
Use coupon code JTTH15S to lower the price from $99.99 to $66.99 (-$33.00)
- Cree XHP35 E2
- Jetbeam 2600mAh micro USB rechargeable 18650 battery included (along with holster, clip, tactical ring, 2 spare orings, lanyard and spare rubber cap)
- max 1300lm ANSI FL1 (3 min turbo step down + 1.1h high 900lm)
- dual switch (side click + tailcap switch)
- power indicator LED in side switch
- two operation modes (outdoor + tactical) with multiple output levels
- min 10 lm (140h using 3500mAh battery)
- 228 meters (748 ft.) range
- one touch strobe hidden in outdoor mode
- momentary on
- patented Jetbeam “triple tail” switch for easy operation with gloves
- stainless clip for EDC
- 18650 or 2x CR123 power source
- constant current LED driver
- compatible with remote switch(sold separately)
HaikeLite SC02 II MTG2 2000Lumens Stainless Steel Head LED Flashlight 26650
Use coupon code HSCO2II to lower the price from $65.99 to $43.60 (-$22.39)
Eagle Eye X7R XP-L V6 1000Lumens 5Modes USB Rechargeable LED Flashlight 18650/26650
Use coupon code X7RSD to lower the price to $21.60 (–28%).
Cool White (1A 6500-7000K) and Neutral White (3A 5000-5500K) versions available.
1PCS GETEED 3.7v 4800mAh 35A High Power 21700 20700 Rechargeable Li-ion Battery
This is probably first widely available 21700 li-ion cell. Use coupon code ET217SD to lower the price to $9.68 (–12%)
Judging from 9.5A discharge plot (below) this cell is well suited to high power mods:
ADEASKA SQ2 Intelligent LCD Display USB Rapid Battery Charger for IMR/Li-ion Ni-MH/Ni-Cd Battery
Use coupon code ADSQ2S to lower the price to $11.69 (–30%)
- 0.5A/1A charge current for li-ion cells
- 0.5A charge current for Ni-Mh/Ni-Cd cells
- standard microUSB power input (DC5V/2A)
- USB output (power bank function)
- realtime voltage monitoring
- battery capacity, time and current display
- refresh function for over-discharged cells
- over discharge protection for USB power bank function (3V +/- 0.2V)
- temperature monitoring
- reverse polarity protection
- 2 years warranty
ADEASKA SQ4 Intelligent LCD Display USB Battery Charger for IMR/Li-ion Ni-MH/Ni-Cd/LiFePO4 Battery
Use coupon code ADASQ4 to lower the price form $39.99 to $26.79 (-$13.20/-33%)
- 0.5A/1.0A/2.0A charge current for li-ion cells
- ability to charge 4 26650/32650/D size batteries at the same time
- 6A max output (all slots combined )
- USB output (power bank function) with 2.1A output
- power bank works with cells in any slots
- internal resistance measuring
- battery capacity, time and current display for each slot
- 2 years warranty
Folomov A4 LCD Display High Current Quick Charge Intelligent Battery Charger 4Slots
Use coupon code FVA4SD to lower the price from $39.95 to $33.96 (-$5.99)
- 250mA/500mA/1000mA/2000mA/3000mA charging current (3A only in two outermost slots)
- compatible with Li-ion/LiFePo4/Ni-Mh/Ni-Cd
- 0V Activation Feature
- high contrast negative STN LCD display (light letters on black background)
- realtime voltage/current/capacity and charge percent display
Astrolux Flashlight Protected Bag Holster For Astrolux S41/S41S/S42/S42S 12.8x3.2cm
Very good quality single 18650 flashlight holster is now for only $1.33 in flash sale.
Fits all Convoy S2/S2+/BLF A6/Astrolux S1/S41/S42 sized lights perfectly. Also good fit for ~90mm blade sized folding pocket knives.
Offer expires on December 21th.
Astrolux S1 XPL 1600LM 7/4modes 3D Mini LED Flashlight 18350
It’s now in flash sale for $14.95
Offer expires in 4 days and 11 hours.
Astrolux S41/S42/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube
It’s now in flash sale for $2.45.
Three colors available: black, red and blue.
subscribing
New multi-function bike light from Xanes is now in preorder for $13.59 (limited to 150pcs), then the price will gradually rise and target price is supposedly set at $20.99.
This is 3 in 1 device (bike light, lantern and power bank) that doesn’t look half bad ![]()
It has 2 x 18650 cells built in (total 4000mAh), claims to deliver 1000lm. COB LED on top serves as lantern - there’s foldable hook on the back and two magnets to affix the lamp to any metal surface. On the bottom side standard USB socket is located to charge any USB rechargeable device.
SKILHUNT H03F XM-L2 U4 1200LM Adjustable LED Flashlight Headlamp
Use coupon code SHH03F to lower the price from $57.95(CW)/$58.95(NW) to $38.99 (-$19.96/-$18.96)
Both cool white and neutral white versions available in stock.
SKILHUNT H03R XM-L2 1200LM Multi-level EDC LED Flashlight Headlamp
Use coupon code SHH03R to lower the price from $52.90(CW)/$53.90(NW) to $35.99 (-$16.91/-$17.91)
