It’s now in flash sale for $50.99 ($92.99). Offer expires in 5 days and 9 hours.
This is the most powerful solar charger in Blitzwolf range. It’s capable of delivering 3.8A of current (it full sun) which is enough to charge at full speed two high power devices (high-end smartphones or tablets). Even smaller Blitzwolf panels can charge smartphones in cloudy day so this should easily power more demanding tablets. Solar cells from SunPower provide unsurpassed conversion efficiency over 23.5%
Blitzwolf chargers offer best value/cost ratio on the market at the moment and quality is very good. Lower powered BlitzWolf® 15W 2A BW-L2 and BlitzWolf® 20W 3A BW-L1 versions have much more reviews, 28W is quite recent.
Good to know. For the price I would suppose the quality control is at best “it works so it’s ok”.
I just found this review: XANES WT518 review by carambola
It seems he had more luck as what he describes is more or less what I would expect from 4$ light.
Well, agree it does work, maybe I even agree its worth $4, but comparing this with cheap convoys…difference is quite obvious in all respects I could think of
Yes, indeed. However, if the restock date will be kept the first two tints should arrive in 3 days, then four tints the next day and the rest two days after that.
I don’t know how big the shipment will be so keep an eye out
Don’t agree. For the price build quality is decent. The UI is the typical cheap one though: high, low, strobe, off. I consider this light a good modding host, I am working at a replacement driver.
Use coupon code 280c58 to lower the price from $249.95 to $142.47 (-$107.48)
uses 4 Cree XP-L Hi V3 LEDs
3600lm
1003m (1097 yds) range
5lm lowest setting
252000 cd peak beam intensity
direct access to both ulrta low(5lm) and turbo (3600lm)
built in voltage indicator accurate to 0.1V
max runtime of 610h (~25.5 days on end)
5 constant modes + 3 hidden blinkies (Strobe, SOS and location beacon)
PRO TIP: As this light features tail tripod mount use this $1.33 attachment to affix it to your keychain.
Your quest for ultimate keychain light is now over
