can you get code for astrolux c8?
BLF X6 X5/Astrolux S2 S3 SS SC Taschenlampe Treiber Taschenlampe Zubehör
Nur US$16.16, kaufen Sie den besten BLF X6 X5/Astrolux S2 S3 SS SC Taschenlampe Treiber Online-Shop zum Großhandelspreis.
petemer this code expired
One more vote for Astrolux C8 code for around 15 usd if possible?
any code for Keeppower 26650 protected batteries?
petemer:
NEW Convoy L2 XPL HI Two Cells Version 1000LM 26650 4Mode LED Flashlight
Convoy L2 is finally restocked (only XP-L HI V2-1A version available so far).
Use coupon code da6f29 to lower the price from $41.99 to only $21.41 (-$20.58 / –49%)
This version comes with 2 cell extension tube and can be used in both single- and two cell configuration.petemer this code expired
Already addressed this - see ✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★ - #798 by petemer
Any good deal for this…
2017FNL expired…
https://www.banggood.com/Astrolux-S1-BLF-A6-A17DD-L-FET-1-2_8-4_35v-7-4-Modes-Flashlight-Driver-p-1009980.html
Only 20% discount code is available - see next post.
Astrolux S1/BLF A6 A17DD-L FET+1 2.8-4.35v 7/4 Modes Flashlight Driver
Using coupon code FLSTNE lowers the price to $4.99.
Deal from here still works:
[image] [image] Astrolux C8 XP-L HI 1300Lumens 7/4modes A6 Driver Tactical EDC LED Flashlight 18650 Use coupon code 3a103e to get 37% discount - price drops to $18.87 This is tried design based on prevalent C8 host with XP-L HI LED (1A and 3B tints available) and BLF A6 FET + 1xAMC driver. This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm,…
price is $18.87.
Not right now - I will try to get it.
There’s (non public) coupon code for:
Keeppower ICR26650 5200mAh 3.7v Protected Rechargeable Li-ion Battery 69.5cm
» PM me if you’re interested.«
There’s also a deal for Imalent protected cells - details in next post.
Imalent MRB-266P45 4500mAh 26650 Rechargeable Battery
Use coupon code FLSTNE for 20% discount - price drops to $12.64
DQG Hobi PLUS 10180 XP-G2 Multimaterial NW 3Modes USB Rechargeable Mini LED Flashlight
Use coupon code YGHP for 20% discount - price drops to $26.36 - $35.96 (depends on the material used).
Ordered 10pcs of A17DD.
Thank you.
Any coupon for this?
Nur US$5.12, kaufen Sie den besten 2LED 17mm DIY Beleuchtung Schalter Satz für Astrolux SS / SC / S2/S3 / BLF X5 X6 LED Taschenlampe Online-Shop zum Großhandelspreis.
yeah i need some too
https://www.banggood.com/BLF-X6X5-Driver-ATTiny25V-Based-and-FET7135-Pow…
coupon?
Hi Petemer! Do you have any coupon for this flashlight:
Thanks!
Not yet - but will try to get one.
https://www.banggood.com/BLF-X6X5-Driver-ATTiny25V-Based-and-FET7135-Power-Channel-Configuration-p-1051559.html
https://www.banggood.com/2LED-17mm-DIY-Lighting-Switch-Set-For-AstroluxBLF-LED-Flashlight-p-1236019.html
No coupons are available right now but I will try to get it.
Rofis MR70 XHP70.2 CW+XP-G2 NW 3500LM Dual Light Multifunction Rechargeable LED Flashlight +26650
Use coupon code YMR70 to lower the price by -$25.26
:arrow_right: 26650 5500mAh battery is included.
Klarus G20L XHP70.2 P2 3000Lumens Dual Switch Brightness USB Rechargeable LED Tactical Flashlight
Use coupon code PG20LA for 36% discount (-$39.58).
