Yes, I have a cheap one from ebay, lx1010bs. I don't know how accurate this. I think it measures higher value than the real (20-30%). I have only relative peak lux values from 3 meters.
Any info is better than no info. BTW do you mind measuring from say at least 10m, preferably 15-20m? What i am trying to do is to let the beam focus and smooth out, when you are farther out the hotspot peak intensity will be easier to get hold of and not only stay at a small place (it smooths out so to speak). Also the meter sensor will not get overloaded, as you can see 24k is too much. Forget about the specs - most guys in the hobby know about the characteristics.
C8 XM-L @ 3.5 is pretty well known. XR-E @ 1.5A with a 44mm aspheric is also guessable. Yours is high but we still can make corrections and give educated somewhat accurate guesses and be around in ballpark.
Your XR-E @ 1.5A with 44mm is probably 55k region in true life (i am expecting decent heatsinking but not excellent, so you get around 1.1A-1.2A true relative performance unless you directly mount to pill). Triple XR-E aspheric is 2.6X, so you get 143k. Could be slightly higher than Olight SR90.
I am waiting for some new flashlights, so I should stop buying a bit till next month at least haha, but I would love to do something similar.
The best zooming I've got now is the Yezl T9 with the Ultrok x2000 big head lens (which is better than the original in the yezl), but this one looks like is far better than that in a bigger host.
Another question would be the battery/es you are using, it could be nice to do it with an 26650, which I guess could fit.
