I wish I had saw yours but I went ahead and ordered from the 2nd link I posted because they had sold a lot of units. If it turns out to be not real or something ill reject the charge through my credit card if I have to. $17.25 was my total. If the Lii is as good as everyone says that should be the definition of bang for the buck. Right now my TR-01 is humming away just fine so I am in no rush. Ill be more interested at the $40-50 price point for a charger if it has really precise IR readings and no potential issues with fans or anything. Now, just time to wait 2 or 3 weeks to get try out the Lii . Thanks for all the information in the thread, it has been great!
I have both C3100 v2.2 and lii 500, also other charger and a 300W hobby charger, i will reccomend definitely the OPUS over the lii-500. I've made a whole long post with many argumentations.
The lii500 is not bad but if you don't care about the opus being PWM, go for it.
Also the PSU from both are pretty decent. I've tested with may Maynuo m9710, i don't know what are people complaining for.
Also i have absolutely no fan issue on my OPUS.
My lii500 overcharges Li ion cell a bit from 4.22 to 4.25V tested with my fluke and my Brymen BM967s
It has different settings you can choose between 4.1V and 4.2. Not sure if there ’s HighVoltage setting for 4.35 should check it later if you need to know. You can calibrate if the voltage is of but you need to contact isdt to get the code to get into that particular setting menu.
I have used it to charge small 12V Pb batteries but I couldn’t figure out if it does trickle charge at the end.
I believe the screen is plastic but don’t quote me on that.
If you check RC forums you’ll find some people who had problems with it and sometimes you can find a fix for it to. I believe the early models had problems with a dark screen but Isdt fixed it now and if you get an early model there are video’s on how to fix it. I’ve read of people blowing their output fuse and isdt posted a picture with which fuse to replace so that’s cool. I haven’t had any problems with it but I haven’t used it regularly.
All in all I like this little charger but beware: you’re gonna need a PS and XT-60plugs to use it and also some other plug (can’t remember the name of them) if you wanne balance charge packs.
Also you’re gonna need a single cell balance plug for charging 18650 in parallel. I know, normally you don’t need it but the voltage and amp reading of this charger is way off if you don’t use one. It uses the balance port to get precise readings.
You can also check the Q6, I believe you can set the end voltage with this one, so u can charge your cells to whatever voltage u want.
BTW: all isdt charger have storage charge setting which is nice to have.
Thank you… :+1:
I was just interested to read what your opinions were. Mine are slightly different as to which one I prefer…. but that is just what I prefer.
Thank you again for the link to your well stated post. :+1:
Hey, thank you for considering a different opinion. World evolves because different points of view make people see the problem in its whole and solutions can come from every perspective
Your welcome… my pleasure. Thank you for offering it in such a concise, straight forward manner.
Now that I have secured a new power supply to replace the sub-par one that came with my BT-C3100 v2.2 they are once again pretty neck & neck for my purposes & in my book. I still lean toward the Lii 500 though.
No prob. I forgot to mention 2 things about psu in each charger.
My Liitokala 2A rated charger delivers 2,000A @11.89V. But mine cuts off power delivery at about 2.2A
Opus 3A rated charger delivers 2.000A @11.86V but it can deliver 3,000 A @11,66V. I don't remember if it has overcurrent protection above 3.5A.item were tested with the same environmental conditions.
I've burned the best psu I had testing the overload protection and I've yet to find a decent one from AliExpress... So I'm scared of ruining the opus one.
I even bought a 12V5A psu with the same form factor of the laptop's PSUs and I barely got 289mA @12V from it.
EDIT
just found my notes for the power supplies
Liitokala
0A 12.26V
1A 12.05V
2A 11.89V
Current protection varies also with temperature... From. Cold 2.3A to 2.2A
Opus
0A 12.28V
1A 12.07V
2A 11,86V
3A 11.66V
4A 11.31V
5A 11.17V
Protection untested
Currents out of ratings were tested just briefly
This is the opus right know attached for a moment.
“My lii500 overcharges Li ion cell a bit from 4.22 to 4.25V”
That is not overcharging 4.20v li-ion.
Recommended charging for 4.20v Li-ion is 4.20v +/- .05v so that is 4.15v to 4.25v.
4.22-4.25v is within specs & not overcharging
Yep I know. That's technically correct. It was just to get the point. The message that was lying beneath my statement, is that I do not like this behavior.
A cell charged at 4.25V gets more stress than one charged at 4.15. Hope you will agree.
This statement: [I even bought a 12V5A psu with the same form factor of the laptop’s PSUs and I barely got 289mA @12V from it. ]
You mean a ‘cheap Chinese’ laptop(like?) power supply?
Or a real laptop PS from a name brand laptop? That’s what I’m using for my Opus and assumed it was doing OK.
But a 4.20v Li-ion charged to 4.15v will never be fully charged.
Charging to 4.25v may stress the cell slightly more which may result in it having a few less cycles but cells are very cheap so it is not a concern to me.
Personally I prefer a charger that charges to 4.22-4.25v to one that only charges to 4.15v (I have a couple of Nitecores that only charge to around 4.15v)
I have 3 Lii-500”s & an Opus 3100 & never use the Opus due to the noisy fan that only lasted a few months before it packed in.
