thanks to you
Just made quick look at sofirn q8. You need button top version for q8 flashlight. My previous link was flat top.
i had already found it thanks,but they are out of stock until 09 February 2021
No no, out of stock is flat top version. But you need button top version which is in stock .
no ,add 4
then click on ” add to cart ”
and you will see the message above :
” The requested quantity for “Sony / Murata Konion US18650VTC6 3000mAh - 30A button top” is not available. ”
they’ve been out of stock for several months, i don’t know what they’re doing,it annoys me and i wrote to them but no response from them
You have to be patient, your order is very small, therefore doesn´t have a priority.
no that’s not it :
if you live in USA maybe you see them : available on their site
but me from France, they wrote well :
= out of stock
and i made a mistake :
i thought i read yesterday on their site that they would be available again on February 9 .Mut i was wrong :
it only concerns the ” flat top ” version
-For the button top they do not announce any availability date it’s worse than i thought! :weary:
Hmm, that´s bad.
I live in Europe, Czech republic.
You have an alternative option, LG HG2 button top. I checked that they are really in stock.
I recommend to use DPD for shipping, have wrong experiences with other options.
https://eu.nkon.nl/rechargeable/li-ion/18650-size/lg-18650-hg2-button.html
thank you,but the vtc6 are better i hope that nkon will answer me it’s been 3 emails that i sent them and still nothing for several days :weary:
Do you have a soldering iron? If so, you can buy flat top VTC6 batteries and put a solder blob on the top of it, to make it a “button” top.
thank you for this information
yes i have a soldering iron
but li-ion batteries scare me a little….because i know they can be explosive with metallic objects in contact…finally that if they touch pole + and pole - at the same time…but hey it scares me anyway
if there is a youtube video, that will reassure me immediately…
but also, where to find the button top for purchase?
You don’t need to solder a “top”, you need to “melt the solder” on the top !
Check this thread.
A friend came home recently and accepted to record me doing this: [Solder blobbing 14500 + 18650 cells with Bi50Pb32Sn18 (Rose's Metal)] Flux employed: Goot Super Soldering Flux. Enjoy! Cheers ^
Check this thread.Solder-blobbing 14500 and 18650 cells with Bi50Sn18Pb32 (Rose's Metal)
thank you for your link
i saw the video and read the posts, and it’s very technical to do…temperature adjustment and welding time …if i badly solder the battery and then it charges badly …
apart from that i removed the plastic wrapper from 1 of my batteries Samsung 30Q who died.
Just to see how the ” button top ” is welded on it .
I bought them from Nkon.nl 2 years ago
here are the pictures of my battery
their welding methods are completely different….
the writings on it, i don’t know what that means, i would have liked to know the date of their manufacture
-I had read this post where the person said that you have to scratch the edge of the battery and if an inscription appears, it is that they are real batteries, no counterfeit :
The 30QT-6 has stronger power, and has a low AC internal resistance of about 11.2 milliohm Better cycle life [image] 30Q KE2T 6 ,mark on heat shrinkable Please refer to link test data and comparison link
and mine is a real one but i knew it because i was told that nkon are serious
I just found this very simple solution: a magnetic button top that would simply land on it ? :
but with this solution, will the battery charge well as original ? and also this magnetic button not being welded, it may move and that scares me a little….
I also found this other solution, but it is more complicated, to do spot welding ,change plastic wrapping of the battery and replace the ring…… you have to have the material and above all know-how
Regarding Sofirn/BLF Q8, Sofirn SP36/Anduril, Haikelite HK04 soda-can style lights that require multiple 18650 batteries — so far I’ve been using flat-top 18650s for them (unprotected button-tops are harder to find from my place, or they are lower-drain types like NCR18650B), but based on my experience with these lights:
- genuine Sanyo NCR18650GA (raised flat-top) work properly (make contact)
- genuine flat-top Sony VTC (VTC6/VTC5) work properly (make contact)
- genuine flat-top LG HG2/MJ1 work properly (make contact)
- however, genuine Samsung 30Q / 35E, which have a bit recessed flat-top, may not always maintain proper contact on the above-mentioned lights, so I would not suggest to use them for these lights.
There’s mention about using magnets on flat-tops — I’ve been using such magnets for single-battery lights (or when 2 batteries in series) that require button-top to make contact with the positive side. But would not suggest using them for the soda-can lights, since these magnets can go out of position and possibly cause a short, which can mean batteries and/or flashlight get a short-circuit - in a not-so-worse case scenario, the spring inside the soda-can light may soften or melt (then disconnects the contact?)… In worse-case scenario, I’m not sure what might happen…
